Name that tool!
Topic author - Posts: 190
- Last Name: Delaney
- * REQUIRED* Type and Year of Model Ts owned: 1922/23 Touring
Name that tool!
Since I have some time on my hands I decided to clean out the storage space under the back seat. In addition to the screw jack, spare parts, and tool kit that I knew were there I found this device and just can't make heads or tails of it.
It looks to be some kind of promotional item although I can't make out the name of the company.
My foot, clad in fashionable Croc, is there for scale.
Re: Name that tool!
It's for opening the oil petcock on the transmission/engine and lowering the dust level on your dirt road...
the older you get, the more valueable this thing will become.
- First Name: Harold
- Last Name: Schwendeman
Re: Name that tool!
To add a bit to what Scott said, the tool is marked "TROP-ARTIC LUBRICANTS", which is an old brand name for a line of Phillips 66 motor oil. Multi-viscosity motor oils were a pretty "big deal" when they were a new concept back in "mid-century" times,....hence the "cutsie" name! Not trying to sound like a "know-it-all", however, it's more a matter of being OLD!!!
I'll bet that tool was a "give-away" if you had a Phillips 66 "service station" do the customary,...."lube, oil & filter" service. FWIW,....harold
Re: Name that tool!
.....well,.....in thinking about it, the name "TROP-ARTIC" appearing on a Model T Ford tool,....that would have been considerably BEFORE multi-viscosity motor oil! However, "TROP-ARTIC" is a Phillips 66 brand name. I guess maybe that name was meant to convince people to use Phillips 66 motor oil for both summer & winter! (???)
Re: Name that tool!
How about "Fred"?
- First Name: Dallas
- Last Name: Landers
Re: Name that tool!
I name alot of my tools. When they slip or break, I use their special names.
- Last Name: Stroud
- Board Member Since: 2011
Re: Name that tool!
Looks like it had a small "peg" on the side that is broken off, made to poke into the outlet on the petcock to make sure it wasn't plugged.
Dallas, I'd bet your tools have some of the same names as mine.
Dave
1925 mostly original coupe.
Re: Name that tool!
Well, since I replaced the lower petcock with a dipstick tube and the upper petcock with larger handle replacement, I guess I'll clean this up and hang it on the wall.
