Starting crank arm question
				Belliott3
Topic author - Posts: 366
 - First Name: Bill
 - Last Name: Elliott
 - * REQUIRED* Type and Year of Model Ts owned: 1916 Model T Touring
 - Board Member Since: 2006
Is there supposed to be a small hole near the end of the starting crank arm for the spring to attach to?  I can't seem to find one on mine, but it's been recently painted and I don't know if the hole was filled in with paint.
				FATMAN
 - First Name: ROBERT
 - Last Name: BERGSTADT
Re: Starting crank arm question
Yes they all have a hole 5 3/4" from the end on the right side in line with bottom of the hole, Bob
				Belliott3
 - First Name: Bill
Thanks, Bob, that's kinda what I thought but couldn't remember exactly where the hole was; your photos and measurements helped tremendously!
It's very common for that hole to be so filled with paint and/or crud that it's hard to find.
				Belliott3
 - First Name: Bill
Alright, now that I've finally located the hole is there a trick to getting that spring on???  It's brand new so it's pretty stiff.
				J1MGOLDEN
 - Last Name: Golden
I had difficulty with adding the new spring and realized the end that is bent over is longer than required.
Grinding off half the length made it much easier to replace.
				J1MGOLDEN
 - Last Name: Golden
				J1MGOLDEN
 - Last Name: Golden
The above message was just a rest, but I over did it.
Nice to see this 2019 Forum actually working again!
