KW Coil Box Id
GEmering
First Name: Gene
Last Name: Emering
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring and 1924 Touring
KW Coil Box Id
Post by GEmering » Tue Jul 23, 2019 5:24 pm
The KW coil box pictured was found in the back seat of a 1913 Ford Touring. The box shows traces of red paint on the front.
It does not appear to be repainted.
All the boxes I’ve seen have black and gold graphics.
Can someone identify the year of the KW box pictured?
Thank you,
Gene
Gene Emering
Newton, New Jersey
Re: KW Coil Box Id
Post by RajoRacer » Tue Jul 23, 2019 6:06 pm
1913, I believe.
GEmering
First Name: Gene
Last Name: Emering
Re: KW Coil Box Id
Post by GEmering » Tue Jul 23, 2019 6:51 pm
Steve,
Do you believe that the traces of red paint are original to the box?
In my very limited experience, I've not seen a KW with red graphics.
Gene
Gene Emering
Newton, New Jersey
havnfun
First Name: Joe
Last Name: Kowalczyk
Re: KW Coil Box Id
Post by havnfun » Tue Jul 23, 2019 6:52 pm
Gene,
Here is a complete discussion around the K-W Coils and box
http://www.mtfca.com/coils/Coils.htm
Regards,
Re: KW Coil Box Id
Post by RajoRacer » Tue Jul 23, 2019 9:03 pm
I cannot verify what was the original color scheme on those switches but I do have a switch cover with red color in it's composition - not sure if it's a NOS or very old reproduction - only red one I've seen. I'll get a photo tomorrow.
Adam
First Name: Adam
Last Name: Doleshal
Re: KW Coil Box Id
Post by Adam » Wed Jul 24, 2019 12:05 am
Here’s one I bought at a swap meet 2 weeks ago. Pretty nice original condition and painted black. Too bad it doesn’t have a lid...
Adam
First Name: Adam
Last Name: Doleshal
Re: KW Coil Box Id
Post by Adam » Wed Jul 24, 2019 9:08 am
Forgot to mention; I posted this to show the seemingly original black paint (not stained & varnished). The brass switch plate is likely a replacement.
Re: KW Coil Box Id
Post by Original Smith » Wed Jul 24, 2019 12:14 pm
A side view of that box would nail it! The red paint on the switch place was done at a later date. The only paint on the switch plate when new was in the KW circle. Your coil box has been revarnished at some point. They were originally the same color as the firewall.
Re: KW Coil Box Id
Post by Original Smith » Thu Jul 25, 2019 12:07 pm
Adam:
If you will look at the top edge of your coilbox, there are traces of the original red stain. You are fortunate to have that box. Randall Andersons brother Jon can make you a new lid. I've discovered not all 1913 KW lids are interchangeable! I've probably owned a half dozen 1913 KW coil boxes over the years.
