iPhone test
Can’t log in? Having a problem with the Forums? Have a question about how something works? Get support here.
D.Yoder
First Name: DEAN
Last Name: YODER
* REQUIRED* Type and Year of Model Ts owned: 19tour,24tour,25rdpu,27rd.26coupe,TT's,& tractor conversions
iPhone test
Post by D.Yoder » Sun Jan 06, 2019 9:14 pm
Test
D.Yoder
First Name: DEAN
Last Name: YODER
Re: iPhone test
Post by D.Yoder » Sun Jan 06, 2019 9:17 pm
Ok I like it! THANKS
Ruxstel24
Last Name: Hanlon
Re: iPhone test
Post by Ruxstel24 » Sun Jan 06, 2019 9:24 pm
Yeah everything is pretty easy from an iPhone...
Except avatars, I think the PC will be the way to go.
Rod
First Name: Rod
Last Name: Barrett
* REQUIRED* Type and Year of Model Ts owned: 1909 Two Pedal Touring, 1910 Wide Track Tourabout, 1912 Towncar, 1912 Touring, 1913 Touring, 1924 Depot Hack, 1925 Front Wheel Drive Speedster
Board Member Since: 2014
Re: iPhone test
Post by Rod » Sun Jan 06, 2019 9:28 pm
I noticed on the iPhone things look a little different. I dont see each persons profile on the right side of the screen.
Ruxstel24
Last Name: Hanlon
Re: iPhone test
Post by Ruxstel24 » Sun Jan 06, 2019 9:30 pm
If you tap someone's name it gives the profile.
I haven't tried the PC yet.
And we can quote someone now ! 8-)
GJScholz
First Name: Gregory
Last Name: Scholz
Re: iPhone test
Post by GJScholz » Mon Jan 07, 2019 10:54 am
On the iPhone, you are seeing the MOBILE feed.
Sometimes you can find a menu item in the app that will request the desktop version of a site. Sometimes it works, sometimes it does not.
Greg Scholz
4th Generation Caretaker
1914 Ford Touring
Survivor Class
http://personal.gregscholz.com/
Esko MN
KD0UYN ‘73
