Differential Leak.
ivaldes1
First Name: Ignacio
Last Name: Valdes
Differential Leak.
Post by ivaldes1 » Sun Sep 22, 2019 10:12 pm
Hi, My 12 rivet differential leaks slowly at the two lower most bolts. A few drops a week. See picture. The fluid level was down as expected when I opened the filler bolt so it isn't communicating with the engine oil. The fill hole does not appear to be leaking. How much torque should the bolts be? I did find the bolts loose a month ago and tightened them but it is still leaking. Is there a no-drama way of fixing this? I took the whole thing apart to replace the thrust washers. I would rather not have to take the whole thing apart again to fix this. It hasn't leaked until about 6 months ago.
-- IV
ivaldes1
First Name: Ignacio
Last Name: Valdes
Re: Differential Leak.
Post by ivaldes1 » Tue Sep 24, 2019 3:57 pm
This differential did not leak for about 2 years so is it normal for them to start leaking? -- IV
Last Name: Strange
Post by CudaMan » Tue Sep 24, 2019 4:17 pm
For a few drops a week, I would slide a butter tub under it to catch the drips and top off the level a couple of times a year. :)
Duey_C
First Name: Duane
Last Name: Cooley
Post by Duey_C » Tue Sep 24, 2019 6:04 pm
At least you got two years out of it before it leaked Ignacio! :)
Mine leaked right away. :oops: Smooth, clean surfaces with the dings and high spots brought down with a file...
I need to do this yet: Perhaps clean the bottom mating surfaces with thinner, dry it and smear on some ultra black.
Good reminder tho! I need to check the fluid level before driving it/after sealing it. Whichever comes first.
Snug.
