Steering box wood block
				70shovelhead
Topic author - Posts: 85
 - First Name: Preston
 - Last Name: Wells
 - * REQUIRED* Type and Year of Model Ts owned: 1923 Runabout, 1926 TT Truck
 - Board Member Since: 2008
Can someone provide the diamensions for the wood block spacer at the steering box/frame.
									70shovelhead
"There is more to life than what we see"
1923 T Roadster
1926 TT Truck
1948 Willys Pickup
1937 Harley WL45
1919 IHC Titan 10-20
1923 T Roadster
1926 TT Truck
1948 Willys Pickup
1937 Harley WL45
Re: Steering box wood block
Here ya go.   Mat'l is hard maple.
				70shovelhead
 - Last Name: Wells
Thats what I needed. Thanks Dan
									70shovelhead
1923 T Roadster
1926 TT Truck
1948 Willys Pickup
1937 Harley WL45
1923 T Roadster
1926 TT Truck
1948 Willys Pickup
1937 Harley WL45
				HPetrino
 - First Name: Henry
 - Last Name: Petrino
Just for the sake of comparison, click on the link below and scroll down to page 116.  You can buy one for $2.50 plus tax and shipping.
http://chaffinsgarage.com/catalog.pdf
There was an earlier version of that block, used before 1911. It is a T shape, and rests on the lower frame rail as well as doing what the later ones do.
RV Anderson did the research on this recently at the Benson Ford Archives.
				HPetrino
 - First Name: Henry
Preston,
One more comment: Your profile says you have a T and a TT. If you're working on the TT you need to know that the steering block on a TT is not the same as the one on a T.
