Another Way To Close The Tailgate
HalSched
First Name: Hal
Last Name: Schedler
* REQUIRED* Type and Year of Model Ts owned: 24 Speedster, 23 RA, 25 Fordor
Post by HalSched » Sun Sep 29, 2019 8:33 pm
Here's an alternate Idea for closing the tailgate on a wood pick up box. It works great. Push the latches out to open and "slam" it to close.
Last Name: Tannehill
Re: Another Way To Close The Tailgate
Post by JTT3 » Mon Sep 30, 2019 8:36 am
That’s a dandy. Is there a raised bead that sort of locks the brackets closed on the tailgate hinge once you slam it shut?
John_manuel
Last Name: Manuel
* REQUIRED* Type and Year of Model Ts owned: 1923 RPU
Post by John_manuel » Mon Sep 30, 2019 10:00 am
I did mine that way and it works really well. Takes a little tweaking to get it just right but it is a great option in my opinion.
Post by John kuehn » Mon Sep 30, 2019 10:05 am
HalSched
Is that a pickup box kit you used or did you fabricate it. I have a 19 Runabout and have been thinking of building a box for it. Thanks and your look good!
John_manuel
Last Name: Manuel
Post by John_manuel » Mon Sep 30, 2019 10:10 am
It doesn't need a bead or shoulder as it will only open when both latches are pushed outward at the same time. Also doesn't require much of a slam, in fact mine closes with a firm push.
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Mon Sep 30, 2019 12:33 pm
Nice work!
Mark Osterman
Last Name: Osterman
Post by Mark Osterman » Mon Sep 30, 2019 12:58 pm
That’s the way it works on my original slide on box.
HalSched
First Name: Hal
Last Name: Schedler
Post by HalSched » Tue Oct 01, 2019 12:04 am
The picure above is my Speedster box and is about 3/4 the size of my Runabout. Here's a few pics of my Runabout:
DSC00677.jpg[/attachment ][attachment=1]DSC00680.jpg
HalSched
First Name: Hal
Last Name: Schedler
Post by HalSched » Tue Oct 01, 2019 12:07 am
PS. I made the wheels too
HalSched
First Name: Hal
Last Name: Schedler
Post by HalSched » Wed Oct 02, 2019 1:31 am
I found a picture of my speedster with the box.
John_manuel
Last Name: Manuel
Post by John_manuel » Wed Oct 02, 2019 9:01 am
My gate hangs down like that when it is open. Does anyone have a clever way of supporting it level with the bed? I would rather not use chains and thought of fabricating some sort of pull out or spin out support. I also toyed with a bracket of some sort which would attach to the gate and slide through a retainer on the inside of the bed. Any one done this?
HalSched
First Name: Hal
Last Name: Schedler
Post by HalSched » Wed Oct 02, 2019 1:42 pm
John_manuel
Last Name: Manuel
Post by John_manuel » Wed Oct 02, 2019 2:03 pm
I had considered something like that and I have some like the ones you are showing but they just don't look right and also seem inadequate. I am thinking of trying to make a curved flat piece about 1/4 of a circle with a right angle bend on one end which would attach to the gate and slide through a yoke attached to the side of the bed. I tried once but could not get the geometry right.
