Do not know if I still have it but I had a mag coil ring that was a couple inches smaller diameter than one for a T. Bolt holes were different also. Any ideas ?
I may still have it packed away somewhere in a box.
Mag coil ring
Dennis_Brown
Topic author - Posts: 261
- First Name: Dennis
- Last Name: Brown
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
Joe Bell
- First Name: Joe
- Last Name: Bell
Re: Mag coil ring
Fordson tractor.
art32mor
- First Name: Art
- Last Name: Morra
- * REQUIRED* Type and Year of Model Ts owned: 24T Touring
Re: Mag coil ring
Agree with Joe
Fordson
Fordson
Re: Mag coil ring
What year/model Fordson? Some Fordson tractors use a mag coil ring that looks identical to T coil ring, except that it is mounted to the Fordson engine block by three evenly spaced bolts instead of four. Knew a guy years ago that thought he had gotten a great coil ring for his T until he went to install it.
I also had one myself without any coils on it, so I got to compare it with a T coil ring. Had the flywheel too. Slightly different but almost the same as a T flywheel. I think I gave them to a tractor guy many years ago.
How about a picture of the mystery coil ring? Could possibly be a '09? They are slightly smaller, but not much.
Re: Mag coil ring
You can go to the Fordson tractor site and get an idea what a Fordson mag ring looks like. I had one and sold mine to them. They were glad to get it for a core rebuild.
- Last Name: House
Re: Mag coil ring
Way e... “Slightly different but almost the same as a T Flywheel”..?? A Fordson Model F Flywheel is 3”-4” thick and will weigh well over 100 lbs.
