Another Way To Close The Tailgate
HalSched
Topic author - Posts: 180
- First Name: Hal
- Last Name: Schedler
- * REQUIRED* Type and Year of Model Ts owned: 24 Speedster, 23 RA, 25 Fordor
Here's an alternate Idea for closing the tailgate on a wood pick up box. It works great. Push the latches out to open and "slam" it to close.
- Last Name: Tannehill
Re: Another Way To Close The Tailgate
That’s a dandy. Is there a raised bead that sort of locks the brackets closed on the tailgate hinge once you slam it shut?
John_manuel
- Last Name: Manuel
- * REQUIRED* Type and Year of Model Ts owned: 1923 RPU
I did mine that way and it works really well. Takes a little tweaking to get it just right but it is a great option in my opinion.
HalSched
Is that a pickup box kit you used or did you fabricate it. I have a 19 Runabout and have been thinking of building a box for it. Thanks and your look good!
John_manuel
- Last Name: Manuel
It doesn't need a bead or shoulder as it will only open when both latches are pushed outward at the same time. Also doesn't require much of a slam, in fact mine closes with a firm push.
- First Name: Dallas
- Last Name: Landers
Nice work!
Mark Osterman
- Last Name: Osterman
That’s the way it works on my original slide on box.
HalSched
- First Name: Hal
The picure above is my Speedster box and is about 3/4 the size of my Runabout. Here's a few pics of my Runabout:
HalSched
- First Name: Hal
PS. I made the wheels too
HalSched
- First Name: Hal
I found a picture of my speedster with the box.
John_manuel
- Last Name: Manuel
My gate hangs down like that when it is open. Does anyone have a clever way of supporting it level with the bed? I would rather not use chains and thought of fabricating some sort of pull out or spin out support. I also toyed with a bracket of some sort which would attach to the gate and slide through a retainer on the inside of the bed. Any one done this?
HalSched
- First Name: Hal
Maybe something like this:
https://www.amazon.com/National-Hardwar ... ay&sr=8-50
John_manuel
- Last Name: Manuel
I had considered something like that and I have some like the ones you are showing but they just don't look right and also seem inadequate. I am thinking of trying to make a curved flat piece about 1/4 of a circle with a right angle bend on one end which would attach to the gate and slide through a yoke attached to the side of the bed. I tried once but could not get the geometry right.
