Early brass parts-Motometer,governor,carbs
Topic author - Posts: 28
- First Name: Debbie
- Last Name: Heidenreich
- * REQUIRED* Type and Year of Model Ts owned: 1912
Items from my husbands garage so I’m not the expert. Please email if interested. I have been unable to assess value. Thx, Debbie
Re: Early brass parts-Motometer,governor,carbs
Debbie, those are really nice items. I am unfamiliar with US prices and will not comment. However, I would advise that you contact someone known to you or your husband in whom you can place trust to give you an idea of their value. Failing that, at least advise those who make offers that you intend to post that offer on this forum before committing to a sale. That way the bargain hunters may be more willing to make their offers more realistic.
The carburetor you show is a Holley H1, used in 1912. It appears to have had had little use, and has the often missing connection for the fuel line. It is worth hundreds of dollars.
Hope this helps, Allan from down under.
- First Name: Mike
- Last Name: Bird
With the Holley carb it looks like it does have the fuel inlet pipe. It does look to be in very good shape, if it has/ hasn’t been rebuilt that would effect cost. Russ Potter is the expert on the carbs. You can contact him here
carbking@soltec.net
carbking@soltec.net
Both Moto-Meter/caps are modern reproductions so would be about what current ones sell for or less.
The lid is missing on the Master Vibrator so ball park might be between 60-100. While it looks good, question is does it work?
The Moto-Meters might be an easy sell, finding someone that needs the Master Vibrator or Handy Gov. might be a little harder.
The only Handy Governor I found was on ebay with a cracked cover sold for $29.
The 1912 Holley, not as rare as one might think. There have been a number of them sold here in the past couple of years. My guesstamate would be in the $300-350 range, but could be less/more.
These are not offers, just suggestions which are subject to change. Remember rare/old does not necessary = high $'s.
I second the suggestion on the carb to contact Russ.
- First Name: Stan
- Last Name: Howe
Mark is right.
Thanks so much. I have the lid for the KW. Posted the wrong picture.
Appreciate all the help. My husband loved the hobby until his stroke. He is unable to help me with pricing. But these are some items in a glass case so I figured they were his treasures thanks againq
- Last Name: Tannehill
You do realize the OP IS ALMOST 4 years old.
- Last Name: Tagert
- * REQUIRED* Type and Year of Model Ts owned: 1926, 1925, 1923, 1921, 1918
Email sent on brass motor meter
- First Name: Mike
- Last Name: Spaziano
Taylorgodiva28 is most likely an AI bot since their profile is short and vague. Plus this is their one and only post to date.
They're bombarding the forum.
Just did a quick scan on the internet. The KW master Vibrator has the coil inside for pricing which is a big + $$$. The example prices of the two boxes didn't mention if they had the coil & if working that would be $$$. So you can see just by the two parts you r
As stated - you can show your Husband some prices he may be able to indicate if to high or to low. If you sell anything - my preference is USPS Priority Mail . Flat Rate Box have a fixed price based on the box that's included in the shipping cost . If you use your own box its based on the box size & weight. Insurance only covers up to $100 so all the items need extra insurance. Insure for selling price + shipping cost. Many shippers don't refund shipping cost if the product is delivered damaged - only if it gets lost before its delivered
I would assume that all these prices + the box is what its value is. All depends on who needs it and condition is everything so I would hesitate to price it as the sum of these parts and the buyer gets a brake on the box & bracket value These were priced to low based on the switch --
Testing these only requires putting the the end under he cap in hot water - if the indicator rises it works
Yep! Back to my soap box!modeltspaz wrote: ↑Wed Jul 05, 2023 12:33 amTaylorgodiva28 is most likely an AI bot since their profile is short and vague. Plus this is their one and only post to date.
