Need help with transmission repair
John Illinois
Topic author - Posts: 173
- Last Name: Burgett
I have been sorting out my 24 and the main problem is the transmission. The low pedal is worn out too bad to adjust. Someone put a spring from frame to pedal To pull it back and I think the notch and support are worn out.
High works using the hand lever,low works with pedal,reverse and brake work. The free neutral drags. The engine slows but does not stop in neutral. With one wheel jacked up, I can turn the wheel by hand in neutral.I can push it around the shop.
My question is,if I have to take the transmission cover off to fix the pedal problems,would I be better off to also pull the engine and check the clutch at the same time. This is my second T and my other one seemed to have less drag in neutral.
Any ideas would be welcome.
Re: Need help with transmission repair
If you have a copy of the Service Manual, go through the steps of adjusting your clutch section, the linkage & finally the bands - this should remedy most of the issues you are experiencing.
It also appears that your pedals could be bent from what would be the stock configuration - reverse should stand proud to the rear and the brake seems to be well forward of where it should be.
John Illinois
I have the service manual. The picture may be misleading. The brake and reverse pedal are in the correct place. The clutch pedal is pulled back as there is no stop for it to catch on.
I think the the notch must be worn. I will have to take it apart to see. It is hard to adjust it because the entire pedal and link are worn out.
My main concern is if I should remove and check the clutch discs as there is quite a bit of drag when it is in neutral with the hand lever. Do worn discs make the neutral drag?
ivaldes1
- First Name: Ignacio
- Last Name: Valdes
John I am no expert having only seriously been in my transmission once for the first time this month. However, I would suspect that it would be the bands as the issue and not the clutch or at least I would suspect the bands first. First step would be to open the inspection hatch and take a look. Send some pictures to this thread please.
No. If they had any influence at all on drag, I would expect them to reduce it.
John Illinois
Thanks for the responses. The bands are probably worn,but as I mentioned, they all work. Being able to pull the low pedal back to the end of the floorboard slot is what puzzles me.I will post pictures when I get into it.
Steve,what should I look for to reduce clutch drag. The car sat for a long time. Maybe congealed oil? One thing, the engine starts easily and runs well.
The transmission does not make noise.
Clutch drag is common before the oil warms up. That's why starting a cold engine may be easier with one rear wheel jacked off the floor. Proper adjustment of the pedal linkage and the clutch fingers should reduce it to a minimum. See pages 246-248.
With the parking brake in neutral position on a level surface, Turn the hand crank. The car should not move when cranking. Then push the car in neutral. The engine should not turn when in neutral. (note, it might creep when the engine is cold, but at running temperature, should not creep).
Take off the inspection plate from the transmission being careful not to drop anything in. The key should be out and anything else which could drop in should be away from the transmission. Inspect the bands. The ears should be pushed apart by the spring when in neutral or high gear. Also rotate the engine and inspect the drums all the way around. They should not have visible cracks. Now push one pedal at a time. The band should start to compress within one inch of forward movement and compress the band until one inch above the floorboard. The band should be completely tight around the drum when one inch above the floor.
An indication of excessive wear in the cam or notch would be that the pedal moves freely until it is close to the floor and then begins to compress the band. When you have this much wear, you will have to tighten the band so much that it will drag when in neutral and completely compress the band when the pedal is below the floorboard.
If all those conditions are correct you will not need to replace the notch or cam, but work on the adjustment of the link between the low pedal and clutch arm. See attachment.
One thing which will cause the clutch pedal to stick down is if the adjustment is too loose and the link goes over center. Last thing to check would be the finger adjustment. If you can get a good solid high gear, you should not need to adjust them. When in high gear, the spring length should be 2 inches.
John Illinois
Steve and Norman thank you for the suggestions and information. I tested the neutral with a push and crank and it is good.
I thought the clutch pedal arm had too much wear to adjust,but I followed the rule “play towards front “and it now has neutral
and low gear. Next I will look at the bands and springs.
John
John
John Illinois
Steve ,Norman and all who posted thank you for your help and suggestions. I tested the neutral by pushing and cranking and it works fine.
I thought the low pedal and link were too worn to set,but I followed the “play forword” rule and it now works. I have neutral and low gear. Next I will check bands and springs. I was looking at my T tools and noticed my band wrench with a long piece of safety wire on it.
John
Oops double post
John
Oops double post
The spring of which I was referring was the clutch spring. The large spring toward the rear of the transmission. If you do anything other than tighten the band adjustments, be sure to stuff rags into the transmission to stop any nut or washer which might accidently drop in. The springs between the band ears are strong and if you loosen the nut when you get to the end of the thread it will suddenly pop off the nut and washer. So be careful. If your low, reverse and brake are working you might not to do anything to those springs.
Note, if the hand lever is all the way forward, the transmission should shift into high when you release the low pedal. Be sure to check the bolt on the clutch lever at the side of the transmission. It should clear the cam on the cross shaft when the lever is all the way forward. If not, perhaps something is bent. or something is preventing the hand lever from being moved all the way forward. Another thing to check is whether the pedal shaft is scraping the floorboard. The pedal moves to the right when you depress it and sometimes it is not touching the floorboard, but scrapes when you push it down. Then it will stick down until you pull it back. In that case, remove some wood from that side of the floorboard.
One other thing which sometimes keeps the pedal from coming all the way back to high is if the brake rods are adjusted too long. When this occurs, they will push forward on the lever at the bottom which will in turn move the hand lever backward and cause the clutch lever bolt to contact the cam when you shift to high preventing it from going all the way into high. The rods should be adjusted so that with the hand lever all the way forward and the brake rods pushed all the way back, you should be able to put the clevis pins in without bending or forcing the rods. After you make adjustment to the rods be sure to check that both rear wheels stop equally when you pull on the parking brake.
