Wood block between 21 body and frame
Sarikatime
Topic author - Posts: 713
- Last Name: Seress
My 21 touring hood slants down towards the rear of the car which indicates the body has to be raised a half of an inch or so for the hood to be straight. The radiator is bolted to the body with only the leather in between so I cannot lower it any. What am I missing? Frank
Re: Wood block between 21 body and frame
Like all T's, your car has a bowed frame. The only true fix is to re-arch the frame
Read this: http://www.mtfca.com/discus/messages/80 ... 1240978095
as well as the rabbit holes it takes you down.
On the bright side, friends have had success at friendly frame shops, with body attached.
HPetrino
- First Name: Henry
- Last Name: Petrino
Just a thought -
When I took my '18 TT apart I discovered that the radiator (which should have been a low radiator) had been replaced with a high one. Nothing lined up. Of course I replaced it with the correct radiator, but at the time my learning curve was steep.
