New accessory item, GUESS
Topic author - Posts: 3384
- Last Name: Morsher
Pretty excited about our new accessory offering. We do these things to keep busy, stay active, stay out of wifeys hair and the bar, and of course to make a buck or two. I thought I’d throw this out with a clue or three. The first to guess correctly HERE will get the first one FREE. 1) they are at the powdercoater right now, should be done in a couple days. 2) it’s an aftermarket accessory, but even the Original Smiths of the hobby MIGHT want one. 3) it’s smaller than a breadbox ( that should eliminate anyone under 50! ) First to guess correctly will get #1 FREE postpaid. PLEASE, NO EMAILS,PHONE CALLS,PMS,PMS REQUESTS, TELEGRAPH MESSAGES,SMOKE SIGNALS OR KNOCKS ON MY DOOR.
- Last Name: Juhl
Re: New accessory item, GUESS
Geez! How about a little clue other than size, like what part of the car it's associated with?
- First Name: Thomas
- Last Name: Hicks
- * REQUIRED* Type and Year of Model Ts owned: '24 TT, '26 TT, '24 Speedster, '26 Speedster
Right hand henway adjuster?
- First Name: Shane
- Last Name: Lach
- * REQUIRED* Type and Year of Model Ts owned: 1927 Tudor and 1921 speedster in progress
Is it the aluminum oil fill extensions?
Hand crank anti-kickback?
- Last Name: Hjortnaes
Then this post belongs on the Parts forum, since it is an accessory.
- First Name: Don
- Last Name: Demio
- * REQUIRED* Type and Year of Model Ts owned: 1919 T
A Gunkalator Armature
- First Name: Henry
- Last Name: Petrino
I know what it is. It's a 3 in 1 pump It pumps water, fuel and oil. I get the prize, right?
- First Name: Susanne
- Last Name: Rohner
Smith's... it's not a Form-a-Jack, is it? (Godawful screw jack things that were the scourge of british car owners in the 50's...)
I like the idea of a combo oil/water pump that runs off the mag, combined with a rectifier and regulator so you can charge a battery from the mag.
How's that? Am I close? --lol--
- Last Name: Rohner
OK... Electrical, Mechanical, or Hydraulic?
- First Name: Chad
- Last Name: Azevedo
Based on size it would be possible to be brackets for stabilizing/reinforcing a wishbone but not the entire wishbone. Next down on size would be a battery box on the running board but thats questionable. A hand brake extension would be small enough and something I could see being more acceptable for purists.
Small - will send post paid..... >>>> Oil Sight gauge
- First Name: Henry
- Last Name: Lee
Oh, Oh Mr Kotter! You have invented the perfect companion for man in a miniature size?
Horshack Hank in Tin-A-See
- Last Name: Nunn
Manifold cooker?
- Last Name: Rodell
Heater.
Combination crank holder / front license plate bracket. The kind that keeps the crank handle up out of the mud
- First Name: Harold
- Last Name: Schwendeman
Mechanically hand operated turn signal semaphore arm thingie!
- First Name: TIMOTHY
- Last Name: MOORE
- * REQUIRED* Type and Year of Model Ts owned: As many as can fit in the buildings, need to add on again.
Yup I got it! I have a few so am out. I know lots of people who don't have one. What color? Good work again Tim!
- First Name: Bob
- Last Name: McDaniel
got to be the new coil points tool
- First Name: Bill
- Last Name: Harper
- * REQUIRED* Type and Year of Model Ts owned: '14 Touring, '20 TT Farm Truck, '24 TT Depot Hack, '24 Coupe, and a 1914 Metz Model 22 Torpedo Runabout
- First Name: Philip
- Last Name: Lawrence
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1917 Runabout, 1919 Touring
- Board Member Since: 2014
It is either a copy of a original design water pump or a copy of an original firewall mounted Marvel Mystery Oil reservoir with all fittings and tubing to hook up directly to the engine.
- First Name: Keith
- Last Name: Townsend
Hand brake extension handle.
That was going to be my guess too.
- First Name: Jim
- Last Name: Davis
Emergency axle. Cable operated brake equalizer.
- First Name: David
- Last Name: Dufault
- * REQUIRED* Type and Year of Model Ts owned: 1915
Brake Light
- First Name: Douglas
- Last Name: Keppler
A non vibrating side view mirror
1924 Touring car
There's No Substitute for Proper Lubrication
- First Name: Joe
- Last Name: Lucas
I don't have one, but it's powder coated and just in time for Christmas, so I really need this......... whatever it is.
If I have to guess, I'll go with an air foil to keep the rear of the car fixed on the ground at high speeds.
None of us is as smart as all of us.
- First Name: James F
- Last Name: Dix
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1921 Coupe
Suicide door coupe sun visor.
- First Name: Dallas
- Last Name: Landers
If Larry would even like it, must be small cans of 100 year old air for the tires. Where did you ever find the air Tim?
- Last Name: Codman
I hope that it is the shake-free mirror. If it is, I will order one.
- First Name: David
- Last Name: Dewey
Hmm,the only thing I can think of that Larry would use (and mostly because CA state law says we should have one) is a driver's side rearview mirror.
Will be interesting to find out what it really is!
T'ake care,
David Dewey
David Dewey
- First Name: Gary
- Last Name: London
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring
Fuel Gauge?
- First Name: Brian
- Last Name: Mettling
- * REQUIRED* Type and Year of Model Ts owned: 1922 touring, 1933 Dodge
- Board Member Since: 2013
Lol.
Variable valve timing
Emission controls
Dashboard Totally integrated power modules (TIPM)
Limited slip thrust washers
E85 compliant carbs
The possibilities are endless.
Emission controls
E85 compliant carbs
- First Name: Les
- Last Name: Schubert
Brian
I have thought about doing variable valve timing. The concept has merit!
I had to go slowly through all the great responses. Nobody has got it yet. Lots of great ideas, but so far only Timmy Moore knows,so he will get #2 gratis. Oh, by the way Tim, they will be any color you want as long as it’s black! That’s clue number 4. #1 is still reserved for the right answer posted here.
Hogs head oiler like the ford Faithful oiling system.
- First Name: Joseph
- Last Name: M
An early screwdriver for the tool kit?
Spring loaded oil can holder
- Last Name: Andulics
- * REQUIRED* Type and Year of Model Ts owned: 1926 Fordor, 1926 Truck, 1927 Roadster GOW, RAJO Sprint car
Dan, did you get some inside help?
BINGO ! Dan is the man !
Bingo ! Dan will be getting one in the mail. A faithful reproduction of a spring loaded oil can holder. Just recd a message they are ready to snag at the powdercoat, so will post a picture of our new baby. Later ,a full spiel will be posted in the classifieds. Thanks for all the great guesses , maybe some new ideas for others. AND , if Original Larry Smith would even use one, I’ll send him one free, too. HAPPY HALLOWEEN !
Nope, no ‘forum leaks’
This forum ain’t like DC!
Just serious thoughts on a desired accessory many T owners would like or need to like as the oil can came with the car’s tool set and no place to store it other than garage shelf. The last guess of the screwdriver with the earlier tool kits made my brain fart happen!
Thanks Tim!! Will use that accessory, now thinking best spot to drill holes in the firewall
Got my Major Award last week from Tim.
What a great accessory! Tim did a terrific job of recreating the spring loaded version of the firewall mount oil can holder.
The spring is good and strong, can won't work loose and holds firm.
Thanks Tim! and thanks for offering these to others, will put mine to use
