evaluating wood spokes
choirsilva
First Name: Christopher
Last Name: Silva
* REQUIRED* Type and Year of Model Ts owned: 1926 Model TT
Post by choirsilva » Sun Nov 03, 2019 10:26 pm
Just picked up the wheels for our 1926 TT after having them soda blasted, All of the spokes are very tight but, the cleaning process did leave them with some missing material and being very rough. When the spokes are tight, are they safe to use? Bondo wood filler followed by paint? I've already had the detachable rims zinc plated and have mounted new tubes, flaps and tires.
Thanks in advance for your advice.
Re: evaluating wood spokes
Post by Mark Gregush » Sun Nov 03, 2019 10:45 pm
Sorry but those are fire wood. They are dried out, split and full of wood borer holes.
choirsilva
Last Name: Silva
Post by choirsilva » Sun Nov 03, 2019 11:10 pm
Mark,
Is there a shop in the Portland area or Northwest that would re-spoke these wheels?
Christopher
Post by Steve Jelf » Sun Nov 03, 2019 11:14 pm
I agree, they are toast. Or perhaps fuel to make toast. For the front wheels you can buy new spokes and install them with a Regan press. I would send the rears to Stutzman for new wood.
Joe Reid
First Name: Joe
Last Name: Reid
* REQUIRED* Type and Year of Model Ts owned: 1919 Coupe, 1920 Roadster, 1923 Touring, 1924 Roadster, 1913 Racer
Post by Joe Reid » Mon Nov 04, 2019 12:21 am
The wood does look a little sad but how does it feel. Soda blasting and blasting in general is tough on wood and shows all the flaws. Does it flex if you push outward on the hubs or is it solid. The problem you will have with a wheel is it may collapse on a corner. Epoxies and fillers do work if the wood is solid. Pressure in and out on the hub of is determining factor.
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Mon Nov 04, 2019 12:41 am
Christopher-
In the Portland area, contact Tom Dessert.
He is in Ridgefield, WA
dessertt at hotmail dot com
Three 6 oh- 9 one oh-forty-three sixty two.
Keith
Post by TRDxB2 » Mon Nov 04, 2019 12:56 am
If you haven't done so already, scrape wood off a spoke or two till you get to some hard wood. Also check the integrity and density of the dowel end of EVERY spoke (poke with a philips screwdriver). Chances are the results will influence you decision.
Post by Allan » Mon Nov 04, 2019 6:59 am
I am not familiar with TT wheels so this comment may be way out of order. The felloes on your rear wheels have a depression on which the end of the spokes rest. On a 23" wheel this would indicate that the felloe had been modified to make spokes fit tighter in the wheel, and that someone had already been there rebuilding that wheel in the past.
Otherwise, In my opinion, the only way to sympathetically strip wooden spokes is by hand using the scraper of your choice. My choice of scraper is ordinary window glass cut into 6" x 1" strips, or a broken bottle will do. This does not raise the grain and takes minimal material off the wood. I suspect that your wheels, in the state shown, would not have passed my rap-with-a-knuckle test and would therefor not be a candidate for stripping.
D Stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Post by D Stroud » Mon Nov 04, 2019 7:20 am
Allan those felloes are original, they have not been modified. That being said, the spokes would be great for making some wheels for yard art, or ink pens. They're toast as for using them for usable wheels. Dave
1925 mostly original coupe.
choirsilva
Last Name: Silva
Post by choirsilva » Mon Nov 04, 2019 6:45 pm
Keith, Thanks for the information, I've sent an email with picks to Tom. I'm not comfortable trying to save any of the spokes on my wheels and am going to go ahead with replacing them. I may do the fronts myself after building a Regan press but, haven't found the rear spokes on any of the supplier's websites.
Christopher
Christopher-
Keith
Post by Mark Gregush » Mon Nov 04, 2019 7:09 pm
Post by Allan » Mon Nov 04, 2019 11:27 pm
Thanks David, I've learned something today.
choirsilva
Last Name: Silva
Post by choirsilva » Tue Nov 05, 2019 6:05 pm
Keith,
I'm delivering my wheels to Tom tomorrow for the re-spoke work and he expects about 4 weeks for return. Thanks for all of your help.
Christopher
D Stroud
First Name: David
Last Name: Stroud
Post by D Stroud » Thu Nov 07, 2019 3:07 am
Allan when I was gathering up parts for my TT (the one Dallas has now), I found two NOS Kelsey "23 rear wheels at different times that had never had hubs installed in them. One had those raised areas at the spoke holes, the other one didn't. Otherwise, they were identical. Don't have any idea why, just one more Model T (TT) mystery. :D Dave
