new sheet metal prep
Topic author - Posts: 57
- First Name: Joe
- Last Name: Gallagher
Does anyone know what is the best way to prep chemically treated fenders and other new sheet metal parts before painting ... Thanks for any help... Joe Gallagher ..joeg48@hotmail.com
- Last Name: hardiman
- * REQUIRED* Type and Year of Model Ts owned: 26 coupe
Re: new sheet metal prep
If it is brand new metal lacquer thinner will do... ms251.
1. Lacquer thinner
2. Fineline surface cleaner(prep sol)
3. PPG DP product apply to bare metal or equivalent product
4. If need body work do it over the DP
5. If after body work and you sand to bare metal DPl afterwards
6. prime area repaired or prime entire part
7. If only area repaired was primed and sanded seal entire part then paint
8. If you primed entire part sand it then paint.
After sanding and blowing the dust … clean with Fineline prior to painting or re-priming part
I have it pretty close.. steps could vary dependent on what happens during each step.
Others may know more!
1. Lacquer thinner
addendum
sand bare metal with 180/220
- First Name: Adam
- Last Name: Doleshal
It’s always best to follow the tech sheets for the primer and paint you are using. Advice from others may not be appropriate for your product, or may leave some details out.
Adam
that has got to be the best answer I've ever seen given for this sort of question
- First Name: Tom
- Last Name: Rootlieb
Wipe it down with lacquer thinner to get the surface oil and grit off from the manufacturing process. Take a paint brush and paint on a coat of metal prep. Then use a scotch brute pad and rub the surface to remove any matter that didn’t come off with the thinner. It will also remove surface rust. As soon as the metal prep touches the surface it will turn a lighter color. This tells you it is removing any remaining contaminates from the pores of the metal. Metal prep is neutralized with water, so when you are done cleaning the part (for example a fender) stand it on end and take a hose and rinse it off throughly. Be sure to wash out the joints between the panels really well. Then use a clean dry rag to wipe the water off while at the same time use compressed air to help blow it off and to make sure you get all the water out of the joints and the part is good and dry. Then you want to seal or prime the part within 10-15 min. I’ve done this for 50yrs. and never had paint lift. You get metal prep at automotive paint supply shops. Somethings you thin it. Sometimes you don’t. It will tell you on the container. Hope this helps.
As blazing saddles states, "we don't need no stink'n tech sheets". lol
- Last Name: Patrick
“Porter Paints” has a great, very effective, easy to use, metal prep. Called “Metal Prep”. Jim Patrick
- Last Name: Dewey
DP primer spec sheet used to state that it bonds better to bare metal, not as well to "treated" metal. I haven't looked at the product for a number of years now, so things may have changed, but back when I did a corrosion resistance test, it verified that--and I thought it was an anomaly of my test, but a discussion with the paint rep confirmed it.
T'ake care,
David Dewey
David Dewey
