Is anyone running Olds 3 port OHV head on their T
steve plowman
Last Name: Plowman
* REQUIRED* Type and Year of Model Ts owned: 1926 cut down tourer
Post by steve plowman » Wed Jan 15, 2020 2:46 pm
Looking for info on Olds 3port head conversions on a T block. What cam works? and what rocker ratio? Apart from the obvious adapter plate and hardware what else did you have to do to make it work? And performance wise what were the gains?
So many questions :D
1926 T Touring cut down with tray back "The Gin Runner"
1926 TwinT straight 8 project
1928 Indian Chout
1940 Indian 640 Stroker
First Name: Henry
Last Name: Lee
Re: Is anyone running Olds 3 port OHV head on their T
Post by Henry K. Lee » Wed Jan 15, 2020 3:04 pm
Yes, and a lot of answers! LOL
Stock 1 to 1 ratio rockers, 280 works well. The valve guides need to be cut down to the height of the head. There are more but depends on other factors such as compression ratio, carburetor, porting, and change in valve size.
All the Best,
Hank
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Wed Jan 15, 2020 7:21 pm
Here you go Steve,
Make a simple tool from bimetal hole saws. This will get you to a correct plumb dimension for small block Chevy valve springs.
This is a fly off with plate reattachment to change to ratio from 1 to 1 to 1 to 1.375 using a 260 cam.
Develops around 280 CFM with over size valves on the flow bench.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Wed Jan 15, 2020 7:22 pm
Now Shut up and HANG ON!
Hope this Helps,
Hank
frontyboy
First Name: dick
Last Name: dock
* REQUIRED* Type and Year of Model Ts owned: T sprint cars
Post by frontyboy » Wed Jan 15, 2020 10:53 pm
Did this a while back on a speedster. I found a 4 cylinder 1928 Chevrolet cam will give more lift that a stipe cam at little or no cost. You take the model t cam bearings out at turn the Chev cam bearing surfaces down to run the cam on the Ford cam bores. If memory serves I think you get a 180 lift.
I presently am building a Fronty overhead speedster and using a 4 cylinder Chev cam in this one as well. The Chev cam works well with a 3 port head it opens the valves longer and breaths better. Makes a nasty sound when running if you do a bit of porting and fab a easy bend open intake, Also a free flowing exhaust helps a great deal.
good luck
frontyboy
steve plowman
Last Name: Plowman
Post by steve plowman » Thu Jan 16, 2020 3:25 am
Hope this Helps,
Hank
Thats a great help. To summarise,
- you milled the rocker stand shafts off to fit the new higher ratio rocker assembly _ what was that off?
- used the start cutter tool to take down the valve guide and fitted SBC valves? and springs?
- fabbed and fitted a funky custom built 3 branch manifold
Looks great 8-)
did you use chevy 4 push rods?
Im hanging on, i can't shut up :lol:
1928 Indian Chout
steve plowman
Last Name: Plowman
Post by steve plowman » Thu Jan 16, 2020 3:27 am
good luck
frontyboy
Thanks, useful info, Im getting a full '28 Chev 4 motor in the deal but it will be going on a T oil pan with a T trans in a Gerber style track car.
1928 Indian Chout
