OT Fastenal shipping
Ruxstel24
Last Name: Hanlon
Post by Ruxstel24 » Mon Feb 04, 2019 10:14 am
I am trying to get a quote to ship a steering column to TX and thought maybe Fastenal would be a good option. Never used them before.
No steering wheel, just the column. Filled out the online form...got a quote of $232.55 !!!! :shock:
I called a spoke with a girl that explained the size was the issue, blah blah.
Does this sound right to those of you who have used them ?
Next stop FedEx ! ;)
Re: OT Fastenal shipping
Post by Original Smith » Mon Feb 04, 2019 10:41 am
You might check Greyhound too.
Tom Hicks
First Name: Thomas
Last Name: Hicks
* REQUIRED* Type and Year of Model Ts owned: '24 TT, '26 TT, '24 Speedster, '26 Speedster
Post by Tom Hicks » Mon Feb 04, 2019 10:57 am
I have shipped two engine with transmissions half way across country for $125 and $150. Each was on a 4 X 4 pallet. Weight is not the issue, it is the dimensions of the package.
BTAIM, your quote sounds way high.
Russ T Fender
First Name: Val
Last Name: Soupios
Post by Russ T Fender » Mon Feb 04, 2019 2:03 pm
I shipped 6 wire wheels strapped to a pallet from Washington State to Florida for under $200 with Fastenal. No issues. I'd check with them again, something does not sound right.
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Mon Feb 04, 2019 2:45 pm
Russ, did you look into USPS or UPS? USPS will go up to 130" length plus circumference for the oversize rate.
Ruxstel24
Last Name: Hanlon
Post by Ruxstel24 » Mon Feb 04, 2019 2:58 pm
I was going to try FedEx first, they are usually cheaper for larger items.
I need to find a box it will fit in and go from there. And pop the wheel off.
Thanks, I can't believe it is a correct quote.
I'm thinking maybe $40 with FedEx...
Jim_PTC_GA
Last Name: Fisher
* REQUIRED* Type and Year of Model Ts owned: 1924, 1925-ish
Post by Jim_PTC_GA » Mon Feb 04, 2019 3:09 pm
I used them for the first time last year to ship a pallet of fenders. Very satisfied with their service and cost.
One thing they don't tell you out right is that if the parts aren't enclosed in a crate their not insured. Its in the small print.
Just give me time to Rust and I'll be good as new. :) Wabi-Sabi
Tmodelt
First Name: Kim
Last Name: Wynn
* REQUIRED* Type and Year of Model Ts owned: 1923 Roadster & 1927 Speedster
Post by Tmodelt » Wed Feb 06, 2019 7:17 pm
I sometimes ship long skinny parts in pvc pipe with threaded end caps. Very rigid packaging with no damage. Can be reused for the return shipment too.
