26 coupe windshield glass removal
Kbailey02
First Name: Keith
Last Name: Bailey
Post by Kbailey02 » Wed Feb 26, 2020 9:18 am
working on a 26 coupe and trying to figure out how to remove windshield glass to have safety glass put in ......... thanks in advance for any help
Rich in Colorado
Last Name: Carlson
* REQUIRED* Type and Year of Model Ts owned: 1922 Center Door 1923 Touring
Re: 26 coupe windshield glass removal
Post by Rich in Colorado » Wed Feb 26, 2020 11:00 am
Keith,
I did a post a while back on how I removed/replaced the glass from my center door. Should be the same, or similar windshield. Link to post below.
https://www.mtfca.com/phpBB3/viewtopic. ... 068#p61068
Good Luck
Rich in Colorado
1922 Model T Center Door
1923 Model T Touring
1928 Model A Tudor
1956 Ford Thunderbird
1966 Ford F250 Camper Special
Kbailey02
First Name: Keith
Last Name: Bailey
Post by Kbailey02 » Wed Feb 26, 2020 11:15 am
thank you....... just got it...... now hopefully the glass shop can do a good install on new one.....also, any input on frame color?????? lots of people do body color but after removing glass im pretty sure frame was originally black
Chris Barker
First Name: Chris
Last Name: Barker
Post by Chris Barker » Wed Feb 26, 2020 11:32 am
My '26 Coupe has a steel frame in two parts, a wide 'U' and a closing piece. Held together by some small screws at two of the corners. These all came out and then I was able to separate the frame parts and gently pull the frame from the glass.
I bought some thin rubber strip (about 0.050" thick?) to fit round the new glass, but I had to cut it to width so that it just shows when in the frame.
Clear silicone seal not only seals but helps lubricate while assembling. I think the new glass is 6mm, but my memory may be incorrect.
It's tricky to get it all back in, but I managed and the end result is fine.
My frame is body colour - the previous owner's choice, but I think that you are right in thinking that they were black, along with the dash panel.
