12V battery
Jon
Topic author - Posts: 11
- First Name: jon
- Last Name: ewing
- * REQUIRED* Type and Year of Model Ts owned: 1915 Model T touring
12V battery
1916 Model T w/magneto only. I would like to install a small 12V battery (trailer emergency brake, burglar alarm system type) to operate LED headlights and an LED combination tail/brake lite mounted inside the kerosene tail lamp. I would like to tie this battery to the Battery side of the coil box for engine starting. Is there any issues with using the 12V system to start the engine, or should I make the entire system 6V?
Re: 12V battery
The mag puts out a lot more than 12 volts when the car is running. It will be fine. Twelve volts won't bother your coils at all. They might even like it.
NHUSA
- First Name: Fred
- Last Name: Dimock
- * REQUIRED* Type and Year of Model Ts owned: 1919 T with Mifflinburg Suburban body
Re: 12V battery
We used a 9 Volt lantern battery to help start our 19 T and ran it on the mag for many years.
When I decided to add LED stop lights I switched to a standard automotive 12 volt battery (put it in a box on the running board) and even had a plug so I can keep my cell phone charged.
As Jeff suggests I think the coils liked the 12 volt battery better than the 9 volt --
NH - Where I used to live - not the carburetor !
Re: 12V battery
Hand crank T's like to start way better on 12v than 6v.
SurfCityGene
- First Name: Gene
- Last Name: Carrothers
Re: 12V battery
Larry, I keep my 12V battery charged up with my Mag using a diode and light bulb charger.
1912 Torpedo Roadster
Re: 12V battery
I keep my 12V battery charged up with my Mag...
That's what I use in my 1915. Here's a page that tells how to do it:
http://dauntlessgeezer.com/DG102.html
dykker5502
- First Name: Michael
- Last Name: Deichmann
Re: 12V battery
Now the question was about 12 Volt and Steves setup is for 6 Volt and the lamp is for 6 Volt as well. Have anyone adapted this very simple setup for 12 Volt? The lamp need to be another, but have anyone found which?
Ford Model T 1914 Touring
Re: 12V battery
Gene says he uses it for 12 volts. Maybe he can tell us if that takes a different bulb.
Re: 12V battery
It isn't about the bulb (at least with respect to 6V vs 12V).
This will explain pretty much all of it: http://www.mtfca.com/discus/messages/41 ... 1416288062
