Looking for information on TT Rear spring bushings
FATMAN
First Name: ROBERT
Last Name: BERGSTADT
Post by FATMAN » Fri Mar 13, 2020 10:29 am
Does anyone have the o.d. and I.d. dimensions on the rear spring and perch bushings for the TT truck, I think the spring one is split and the perch ones are not, 2 different O.D.'S thank you, Bob
HPetrino
First Name: Henry
Last Name: Petrino
Re: Looking for information on TT Rear spring bushings
Post by HPetrino » Fri Mar 13, 2020 1:16 pm
Bob,
I don't know the answer to your question, but I think there's a dimension you've overlooked. I believe the early TT rear spring perch was narrower than the later ones and used spacers on each side. The perch bushings in these early units would be shorter than the later perches and bushings which were the same size as the spring without the spacers.
Anyhow, that's how I understand it.
FATMAN
First Name: ROBERT
Post by FATMAN » Fri Mar 13, 2020 2:15 pm
If you measure both perches, the same bushing was used, the spacer takes up for the short perch, thank you, Bob
Post by Steve Jelf » Fri Mar 13, 2020 10:47 pm
I would measure the shackle and measure the hole in the perch. I bet both of them will be a standard size, like 9/16 and 11/16 or 5/8 and 3/4, and the bushings would match. I hope somebody seeing this will have a bushing to measure.
FATMAN
First Name: ROBERT
Post by FATMAN » Sat Mar 14, 2020 9:15 am
I have the perch and bushing but no main leaf for the spring to go by, Bob
Andy Loso
First Name: Andy
Last Name: Loso
Post by Andy Loso » Sat Mar 14, 2020 9:35 am
Bob,
I'll see what I can scrounge up for you this afternoon. Heading out to the local T club work meeting.
Andy
FATMAN
First Name: ROBERT
Post by FATMAN » Sat Mar 14, 2020 9:40 am
Thanks Andy, Bob
Andy Loso
First Name: Andy
Last Name: Loso
Post by Andy Loso » Sat Mar 14, 2020 5:10 pm
Bore I'd is .937
FATMAN
First Name: ROBERT
Post by FATMAN » Sun Mar 15, 2020 10:28 am
Andy, is that the bore in the main leaf, also the bushing in the main leaf is it solid or split? Bob
Andy Loso
First Name: Andy
Last Name: Loso
Post by Andy Loso » Mon Mar 16, 2020 10:45 am
That is the of the main leaf, the bushing is solid
