Unable to keyword search “2018 & Prior Forum”
Topic author - Posts: 2437
- Last Name: Patrick
Is there any reason why I am unable to keyword search the “2018 & Prior Forum”? When I try to access it, the “2018 & Prior Forum” page appears, but when I try to access the keyword search feature, a notice comes up saying “the server encountered an internal error or misconfiguration and was unable to complete your request” and says to contact the MTFCA server administrator, so here I am. Jim Patrick
Re: Unable to keyword search “2018 & Prior Forum”
I just use a google search and am able to access/read subjects posted that go back for quite a few years. "mtfca; magneto" yields;
https://www.google.com/search?client=fi ... 3B+magneto
- First Name: Jim
- Last Name: Wilson
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster Pickup
Used Google search but the results are limited and did not included the thread I previously found and am interested in resurrecting. Is there no answer re this issue.
Are others having this same problem of not being able to access the “2018 and prior forums” keyword search? Jim Patrick
- First Name: Chris
- Last Name: Brancaccio
- * REQUIRED* Type and Year of Model Ts owned: 1909 Roadster 1915 Coupelet 1923 Coupe 1926 Touring
Per Mark above, Google is the best to use for searching, always has been.
"your search term" site:www.mftca.com
rear axle drawings site:www.mftca.com
2 or 3 words is usually sufficient, leave out all the small words.
The last update to the website software broke some of the old forum software code which I will have a look at as time permits.
Chris
Chris
Chris Brancaccio
MTFCA Webmaster
MTFCA Forum Admin
MTFCA Webmaster
MTFCA Forum Admin
- First Name: Jim
- Last Name: Wilson
Thanks for the input. What is strange, last week a few times I was able to do a word search the "old way" and it worked fine then didn't. It does not appear that when I use the Google method that I get all the results I did with the old way but may but may be my imagination.
Jim
Jim
If you know who the author try that in the google search, for example;
mtfca jiminbartow
https://www.google.com/search?client=fi ... iminbartow
mtfca jiminbartow
