Where does this brace go
bnchief
First Name: Steven
Last Name: White
Post by bnchief » Tue May 26, 2020 2:59 pm
The top two brackets are fender brackets the top is front fender on 27 fordor the second is the rear fender bracket I have no clue what the third bracket is could it have been a brace for the 26-27 fuel tank i cannot figure out where it came from does not match up with fenders or anything else.
bnchief
First Name: Steven
Last Name: White
Re: Where does this brace go
Post by bnchief » Tue May 26, 2020 3:00 pm
Wll i am clueless as to how to post a picture here it came up in the preview
Post by Mark Gregush » Tue May 26, 2020 3:22 pm
Try refreshing your screen. I can see them.
bnchief
First Name: Steven
Last Name: White
Post by bnchief » Tue May 26, 2020 3:41 pm
Thanks Mark i finally got it to go it is a little confusing to get it to work
bnchief
First Name: Steven
Last Name: White
Post by bnchief » Tue May 26, 2020 4:10 pm
Post by Wayne Sheldon » Tue May 26, 2020 5:41 pm
Just curious. Are you sure it isn't a somewhat deformed front fender bracket? I am not an "improved" Ford expert, but I do know that Ford changed the brackets and headlamp mounting to at least four variations which may explain the difference in the holes not being the same. The one bracket (lower in your picture) appears to have been bent down badly, with a significant change in the arc, and buckling on both ends. I cannot tell from the photo if the overall length would match or not.
bnchief
First Name: Steven
Last Name: White
Post by bnchief » Tue May 26, 2020 5:58 pm
Wayne that is what I do not know each end of that brace has two small holes and it is kind o vee-ed at the end where the bolts are the other two brackets match up to the body at the and frame at the front and match up with the holes in the fender and it could be an brace that does not even go with this car as there is only one of them.
