Brake Rods
Dave S
First Name: David
Last Name: Simmering
* REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1925 Coupe, 1926 Roadster Pickup
Brake Rods
Post by Dave S » Wed Feb 26, 2020 2:13 pm
Does anyone know the difference between 17 to 25 T brake rods and 26,27 brake rods ? Thanks for any help.
Re: Brake Rods
Post by RajoRacer » Wed Feb 26, 2020 2:20 pm
'26 - '27 rods are straight - the earlier have a bend to clear the rear radius rod.
Andy Loso
First Name: Andy
Last Name: Loso
Re: Brake Rods
Post by Andy Loso » Wed Feb 26, 2020 2:23 pm
26-27 are shorter and straight
18-25 are longer and have a arch to clear the radius rod
Dave S
First Name: David
Re: Brake Rods
Post by Dave S » Wed Feb 26, 2020 2:51 pm
Thank you. Now that I knew what to look for, I located a set of straight ones. They seem to be one inch shorter. Is that correct? It will make it a lot easier to adjust my rear brakes !
Re: Brake Rods
Post by DanTreace » Wed Feb 26, 2020 8:32 pm
Yes the large brake drum '26-'27 rods are shorter and straight because the longer brake lever at the larger backing plate is farther forward than on the small drum ('25 and earlier) shorter lever backing plate.
