			If you need help logging in, or have question about how something works, use the Support forum located here
Support Forum
Complete set of Forum Rules  Forum Rules
 Ruxstel24
- Last Name: Hanlon
						Post
								by Ruxstel24 » Mon Feb 04, 2019 10:14 am
			I am trying to get a quote to ship a steering column to TX and thought maybe Fastenal would be a good option. Never used them before.
No steering wheel, just the column. Filled out the online form...got a quote of $232.55 !!!!
I called a spoke with a girl that explained the size was the issue, blah blah.
Does this sound right to those of you who have used them ?
Next stop FedEx !
						Post
								by Original Smith » Mon Feb 04, 2019 10:41 am
			You might check Greyhound too.
 Tom Hicks
- First Name: Thomas
- Last Name: Hicks
- * REQUIRED* Type and Year of Model Ts owned: '24 TT, '26 TT, '24 Speedster, '26 Speedster
						Post
								by Tom Hicks » Mon Feb 04, 2019 10:57 am
			I have shipped two engine with transmissions half way across country for $125 and $150.  Each was on a 4 X 4 pallet.  Weight is not the issue, it is the dimensions of the package.
BTAIM, your quote sounds way high.
 Russ T Fender
- First Name: Val
- Last Name: Soupios
						Post
								by Russ T Fender » Mon Feb 04, 2019 2:03 pm
			I shipped 6 wire wheels strapped to a pallet from Washington State to Florida for under $200 with Fastenal.  No issues.  I'd check with them again, something does not sound right.
- First Name: Jeff
- Last Name: Humble
- Board Member Since: 2006
						Post
								by Humblej » Mon Feb 04, 2019 2:45 pm
			Russ, did you look into USPS or UPS? USPS will go up to 130" length plus circumference for the oversize rate.
 Ruxstel24
- Last Name: Hanlon
						Post
								by Ruxstel24 » Mon Feb 04, 2019 2:58 pm
			I was going to try FedEx first, they are usually cheaper for larger items.
I need to find a box it will fit in and go from there. And pop the wheel off.
Thanks, I can't believe it is a correct quote.
I'm thinking maybe $40 with FedEx...
 Jim_PTC_GA
- Last Name: Fisher
- * REQUIRED* Type and Year of Model Ts owned: 1924, 1925-ish
						Post
								by Jim_PTC_GA » Mon Feb 04, 2019 3:09 pm
			I used them for the first time last year to ship a pallet of fenders. Very satisfied with their service and cost.
One thing they don't tell you out right is that if the parts aren't enclosed in a crate their not insured. Its in the small print.
									Just give me time to Rust and I'll be good as new.
 Wabi-Sabi
 Tmodelt
- First Name: Kim
- Last Name: Wynn
- * REQUIRED* Type and Year of Model Ts owned: 1923 Roadster & 1927 Speedster
						Post
								by Tmodelt » Wed Feb 06, 2019 7:17 pm
			I sometimes ship long skinny parts in pvc pipe with threaded end caps. Very rigid packaging with no damage. Can be reused for the return shipment too.
