Early Clutch Slip Ring - Newer Drive Plate
fbergski
First Name: Philip
Last Name: Berg
* REQUIRED* Type and Year of Model Ts owned: 1911 Touring 1916 Coupelet
Post by fbergski » Thu May 07, 2020 5:11 pm
Unknown to me newer clutch drive plates do not have the keyway cut into them as the early clutch drive plates have. I had to use a newer drive plate for my 11 trans rebuild, the clutch slip ring has a slot for a keyway. The question is can I still use it or get a later slip ring?
Thx
Last Name: van Ekeren
Re: Early Clutch Slip Ring - Newer Drive Plate
Post by Kerry » Thu May 07, 2020 5:39 pm
Yes you can.
