Head Gasket Failures
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Tue Aug 11, 2020 6:37 am
Been noticing in the pass few years the new copper head gaskets with non asbestos filler have been failing at a very large rate. Blow out of heat resistant material happens normally right at the fire ring support. This is happening to even non Ford cars, ie, Chevy, Dodge, etc. I use a spray copper shellac but it is not really helping that much. Have noticed going back multiple times after the engine has cooled and re-torquing the head bolts does. Can not believe how much torque it takes to re-torque sometimes. The filler heat resistant material appears to deteriorate after heat cycles. Just thought you all should be made aware of this.
All the Best,
Last Name: van Ekeren
Re: Head Gasket Failures
Post by Kerry » Tue Aug 11, 2020 7:10 am
Never had a problem with them myself, but then I re-torque the cast iron heads when hot and aluminium when cold like one is supposed too. :)
jab35
Last Name: Bartsch
Post by jab35 » Tue Aug 11, 2020 9:50 am
" Can not believe how much torque it takes to re-torque sometimes" Pls elaborate-- assuming less torque needed than what was applied previously? How much less, a few % lower, half as much, etc?
And should this be done hot or cold? Thanks, jb
Post by Steve Jelf » Tue Aug 11, 2020 11:09 am
Adam Doleshal uses this gasket and says it's superior, so I'm going to give it a try. It also costs a little less than copper.
Post by RajoRacer » Tue Aug 11, 2020 11:12 am
When I was regularly building engines (until a couple years ago) or doing engine servicing, I would use copper coat on the copper head gaskets and go through a minimum of 3 to 4 heat & cooling cycles - re-torquing usually the next morning COLD - 30 + years and yet to have a reported failure.
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Board Member Since: 2010
Post by Charlie B in N.J. » Tue Aug 11, 2020 11:13 am
What I’ve always heard and done is to install the head torque it run it to operating temperature then let it cool overnight and retorque. Period. Retorquing when hot will allow the metal to shrink when cold leading to guess what.
Post by Norman Kling » Tue Aug 11, 2020 11:15 am
I have not had a failure, however, I check the flatness of both head and block before I install a new gasket, and I also check the bolt lengths so they do not bottom out before the head is completely tightened. I warm up the engine for a few minutes without driving the car. Then re-torque the bolts hot with cast iron or cold with aluminum. Then I drive a short distance and re-torque again. For the first few times I run the engine I check torque again until it holds torque of 50 ft lbs. Then I do not re-torque anymore and seems to be fine.
Bill Anziani
First Name: Bill
Last Name: Anziani
Post by Bill Anziani » Tue Aug 11, 2020 1:01 pm
Just had that happen to my 24 . I had the engine completely gone thru around three months ago.
This past weekend, at the upper front corner, it blew out
Post by RajoRacer » Tue Aug 11, 2020 1:18 pm
Did you re-torque after several heat & cooling cycles & were you informed to do that by your builder ???
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Tue Aug 11, 2020 3:08 pm
New style gaskets like a Felpro have not failed just the new non asbestos copper ones.
Andy Loso
First Name: Andy
Last Name: Loso
Post by Andy Loso » Tue Aug 11, 2020 5:22 pm
Well Steve,
Are you going to enlighten us as to wear to purchase them?
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Tue Aug 11, 2020 6:37 pm
I stock them. Email me thru the forum contact.
Last Name: Strange
Post by CudaMan » Tue Aug 11, 2020 8:02 pm
Hi Adam, I just sent you an email, thanks. :)
RGould1910
Last Name: Gould
Post by RGould1910 » Wed Aug 12, 2020 11:03 pm
Its not just the headgaskets! The copper clad manifold gaskets and the copper washers use what appear to be the same filler material. I had an intake leak I was unable to cure after six tries using one or the other. Finally resolved with period asbestos copper clad gaskets.
John.Zibell
Last Name: Zibell
Post by John.Zibell » Thu Aug 13, 2020 11:33 am
Steve, where can you get these? I look at a couple vendor sites and it isn't listed. Also searched on the name and part number and came up empty.
1926 Tudor
Post by Steve Jelf » Thu Aug 13, 2020 12:08 pm
You can get them from Adam.
DickC
First Name: Dick
Last Name: Cruickshank
Post by DickC » Sun Aug 16, 2020 6:38 pm
I have not had the gasket "blow out" but have had head gasket leaks. Mine were do to using the old head bolts after a rebuild or head shaving. I found that the old head bolts will bottom out and one thinks they are torquing the head but the are just over tightening the bolt. I know most of you are smarter than me and have not had that experience to learn by.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Sun Aug 16, 2020 6:46 pm
Dick no one is immune from simple mistakes, we are all human!
