aughhh...nuts
NU2theT
Topic author - Posts: 214
- Last Name: Wendt
- * REQUIRED* Type and Year of Model Ts owned: 1926 Fordor
aughhh...nuts
Getting the front and rear bumpers back on the Fordor, thanks Jeff Humble. I wanted to find the 9/16-18 square nuts that hold the outer bumper clamps to the backing plates and found them item #56NSQ8/fine @ Ziegler bolt in Canton Ohio.
1-800-362-0628
1-800-362-0628
- First Name: Jeff
- Last Name: Humble
- Board Member Since: 2006
Re: aughhh...nuts
Scott, I do not remember those being square nuts, I think they were fine thread hex nuts I took off. Please post pictures when you are done.
NU2theT
- Last Name: Wendt
Re: aughhh...nuts
Jeff you are right the ones I got from you are regular hex nuts, the reproduction sets have square nuts. Will stick with the regular hex nuts as I recently talked with someone @ Ziegler after trying to order based on their web site info as square nuts available in 9/16-18 but are no longer available.
I just dropped the bumper face bars off to powder coat along with a set of wire wheels, should have them back in 3-4 weeks and will post pictures then.
NU2theT
- Last Name: Wendt
Re: aughhh...nuts
After a long search for originals, bumpers back from powder coating and installed. Thanks again Jeff Humble and MTFCA classified.
Re: aughhh...nuts
I have not seen bumpers power coated or painted. The original ones I have seen were nickel plated,and many have Chromed them.
NU2theT
- Last Name: Wendt
Re: aughhh...nuts
Well now you haveNorman Kling wrote: ↑Tue Sep 22, 2020 8:52 pmI have not seen bumpers power coated or painted. The original ones I have seen were nickel plated,and many have Chromed them.
- First Name: Jeff
- Last Name: Humble
Re: aughhh...nuts
Nice to see them back in use again. I do like the look of long bar rear bumpers. Wish they had fit my coupe.
