Thrust washers
wrees
First Name: Walter
Last Name: Rees
Thrust washers
Post by wrees » Tue Mar 30, 2021 10:09 am
When replacing thrust washers, do thrust plates go on either side of thrust washers or both towards pumpkin?
Re: Thrust washers
Post by Steve Jelf » Tue Mar 30, 2021 10:22 am
Sandwich. Steel bread, bronze filling.:D
Re: Thrust washers
Post by Mark Gregush » Tue Mar 30, 2021 10:37 am
And steel thrust washers are kept from rotating by pins in the axle housings and on the differential cases.
jab35
Last Name: Bartsch
Re: Thrust washers
Post by jab35 » Tue Mar 30, 2021 11:56 am
Walter: If those pins are worn away or missing you need to install new ones before assembling the unit. The 'Axle Handbook" explains this. Without the pins holding the steel washers in place it's possible for the washers to ride on the axle shaft and wear a groove in the shaft. If this has already occured, I suggest replacing the axle out of safety concerns. Good luck.
