old photo Winnipeg 1912
Colin Mavins
First Name: Colin
Last Name: Mavins
Post by Colin Mavins » Sun Mar 10, 2019 5:08 pm
27 early Russell cars, today there are none in Winnipeg . This is Winnipeg 1912 the cars you can see all have 1912 plates black with white crest and numbers this was a cab service
HornsRus
First Name: Charley
Last Name: Shaver
* REQUIRED* Type and Year of Model Ts owned: 1913
Re: old photo Winnipeg 1912
Post by HornsRus » Sun Mar 10, 2019 5:17 pm
mine is a 1911 mod 22. charley
pfindlay
First Name: Peter
Last Name: Findlay
Post by pfindlay » Mon Mar 11, 2019 3:39 pm
Great picture. When you consider that they only made about 200 cars per year, that's quite a selection to end up in Winnipeg. They appear to be 1911 and 1912 models. The ones with the crank in the "up" position are 1912.
Charlie, I believe the closest car (far left) is a 1911 Model 22.
Peter
flatbroke3
First Name: harold
Last Name: musolf
* REQUIRED* Type and Year of Model Ts owned: 1911 touring 1926 touring 1913 touring
Board Member Since: 2010
Post by flatbroke3 » Mon Mar 11, 2019 4:05 pm
I am told this is a Russell motor, correct?
Harold
flatbroke3
First Name: harold
Last Name: musolf
Post by flatbroke3 » Mon Mar 11, 2019 4:07 pm
well only one picture posted , so here's the other
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Mon Mar 11, 2019 7:14 pm
I probably own one of the cars from that line up. It is a 1912 Torpedo roadster. Model R engine (286 cu in). Allegedly bought new by some Winnipeg lawyer. One of 4 Russels i own. Used to have 5, but pfindlay bought one last year!! All good
HornsRus
First Name: Charley
Last Name: Shaver
Post by HornsRus » Mon Mar 11, 2019 7:24 pm
i still need a parts book for my mod 22. charley
pfindlay
First Name: Peter
Last Name: Findlay
Post by pfindlay » Thu Mar 14, 2019 2:21 am
Harold, there seem to be no remaining examples of large early Russell engines so anything is possible, but I doubt it for these reasons:
1. if it is a 50 hp engine, Russell did not make them until 1908. (They made a 40hp in 1907)
2. The only early Russell 4 cyl engines I've seen (not Knight) have the Russell logo cast right into the valve cover as seen in the picture below. The picture shows a 1910, but I've seen a 1908/9 24hp Russell 4 cyl engine and it has the same Russell casting.
3. The 1908/9 and 1910 Russell engines I've seen have the intake and exhaust manifolds on the right side of the engine, unlike yours. (Although the valves appear to be on the left? Not too efficient.)
However, it's possible that the early 50hp engines were different. If you have an engine number that may help. It should probably be in the 300 - 1000 range if it is a 1908/9.
I'd be interested to hear if you find any more information about your engine.
Peter
pfindlay
First Name: Peter
Last Name: Findlay
Post by pfindlay » Thu Mar 14, 2019 4:28 pm
A correction to my previous post - those covers on the left side of the block must be inspection covers. I can see the valve ports on the right side of the engine.
