Stuck in Gear after Sitting for some time
Ed Gallagher
First Name: Edward
Last Name: Gallagher
Post by Ed Gallagher » Sun Aug 29, 2021 1:58 pm
My 26 T had the transmission rebuilt many years ago. I'm finally getting to the restoration. I would occasionally crank the engine over the years. Now I had it on jacks and when I crank a wheel turns. Off the jacks and it won't roll. Something is locking it up in gear. Any suggestions on cause and how to fix? Thanks in advance. :)
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Re: Stuck in Gear after Sitting for some time
Post by ThreePedalTapDancer » Sun Aug 29, 2021 2:50 pm
Possibly stuck starter bendix.
HalSched
First Name: Hal
Last Name: Schedler
* REQUIRED* Type and Year of Model Ts owned: 24 Speedster, 23 RA, 25 Fordor
Post by HalSched » Sun Aug 29, 2021 3:25 pm
Most, if not all, Model ts "creep" when started cold. Some folks say they adjust the high fingers so there is no creep but in 70 years I have not been able to do it. If you park your T with the high lever forward it squeezes the oil out from between the high discs and it (supposedly) reduces the amout of "creep". The back wheels will spin if they are jacked up when you start your T. The colder it is, the worse the "creep"
Post by Jerry VanOoteghem » Sun Aug 29, 2021 5:03 pm
Put in neutral and rock the car back and forth to break loose the high speed clutch discs. Most likely just gummed up and "glued" together from sitting.
Post by Jerry VanOoteghem » Sun Aug 29, 2021 5:15 pm
Don't make duplicate posts. It messes things up and gets confusing. Just reply to your original post. ;)
viewtopic.php?f=2&t=23211
Ed Gallagher
First Name: Edward
Post by Ed Gallagher » Mon Aug 30, 2021 12:14 am
Thought the first one didn't take, will be careful! :D
