TT truck axel keys
Mikes 1912
Topic author - Posts: 125
- First Name: Lester
- Last Name: Husted
- * REQUIRED* Type and Year of Model Ts owned: 20
TT truck axel keys
Where can I find axel keys for a TT truck? Any one have a picture and measurements for the key? Need 2 Thanks. mikes48ford@q.com
tmodeldriver
- First Name: Robert
- Last Name: Hester
- * REQUIRED* Type and Year of Model Ts owned: 26 touring, 27 touring, 22 TT
Re: TT truck axel keys
Hi, Lester. I checked a TT axle I have on hand and I see that you will need 5/16" square keystock about 3 1/2" long for your truck. Your local hardware store may have it. I see that Amazon has it in 12" lengths for about eight dollars. You can just saw it to the length you need, dress up the ends and fit it to your axle and hub. The keyway on the axle is rounded up at the inner end. This is due to the machining process. Your key should stop short of this area. Hope this helps. Bob
I don't think that 5/16 fits the slot as it should. The correct key stock as I recall is different. Mikes 1912 I sent you an email. If you don't get it check your spam.
AandTman
- First Name: Donald
- Last Name: Vagasky
- * REQUIRED* Type and Year of Model Ts owned: 26 Roadster 26 Touring 25TT C Cab express 26 Ames Speedster
I have one that looks like it's NOS and it measures .3150. That is 8.00 MM.
