Small rear axle brake drums
dang.1922
Topic author - Posts: 57
- Last Name: Greger
Is anyone making the small rear drums, the vendors tell me that they are discontinued now. Thank You—-Dan
- Last Name: Hatch
Re: Small rear axle brake drums
What is wrong with a good used drum?
I'm with Dan - I have a 5 gallon bucket of them !
Probably discontinued due to low demand. That's one of the original parts so plentiful they're hard to give away.
dang.1922
- Last Name: Greger
One of my drums is cracked and I have never picked up any used ones to have around. I thought I would try the venders first before looking for a used one. Dan
- Last Name: Strange
- Board Member Since: 2013
I wish cast iron drums were available for Model Ts, like they are for Model As. I suspect they would provide a higher friction coefficient for external band brakes.
walber
- First Name: Walt
- Last Name: Berdan
- * REQUIRED* Type and Year of Model Ts owned: '18 Speedster had 25 touring and 26 coupe
Nash Metropolitan drums are the right size and with a bit of work on a lathe on the inner face and re drilling the bolt holes they work fine. They are also reproduced and not terribly expensive at $40 or $45 each).
dang.1922
- Last Name: Greger
Thank You for the information on the drums, a friend of mine had an extra one so I am set to go. ---Dan
