WTB 26/27 roadster body
Topic author - Posts: 133
- First Name: Jennifer
- Last Name: Pierce
Finally finished most of the running gear and directed my focus to my roadster body - only to discover a former owner had pop-riveted patch panels along the entire length of both side of the body (firewall to back of bucket) to cover up rusted out panels and (unfortunately) a significant amount of the subframe is also rusted out or paper thin…
Not sure I can manage trying to replace the subframe, so testing the waters to see if anyone has a 26/27 roadster body with solid subframe they might consider selling.
Please let me know what you have!
Thank you!!
Jennifer
Aka ModelTGal
Thank you!!
Jennifer
Aka ModelTGal
- Last Name: Tannehill
Re: WTB 26/27 roadster body
Bump for my friend, let’s try to help out.
- First Name: Henry
- Last Name: Lee
Jennifer,
It is not hard to bend up new frame rails and attach. Replacing sometimes better than trying to find good used ones that surprisingly has the same issues. I have the heavy sheet metal brake if you require me to fabricate. Just Sayin, been there to many times.
Jennifer if anyone can fabricate the subframe Hanks the guy. Highly skilled at fabrication among many things. Review his “going dry thread.” Genius!
- Last Name: Pierce
Hi Hank, thank you for the offer to assist - I sent you an email with photos of the passenger side sub frame (the parts which still exist) to give you an idea of the issue. Not really enough there to provide you complete measurements, etc. I fear the driver side is going to be similar, as I can see more pop rivets...Henry K. Lee wrote: ↑Mon Apr 25, 2022 11:36 amJennifer,
Please let me know your thoughts, I am somewhat heartbroken to have discovered the amount of damage concealed behind seemingly solid body panels. (pop rivets, 1/4" of bondo, etc.)
Jennifer
- Last Name: Pierce
Still looking. The damage to the subframe and body is so severe I’ve been advised by several folks to just replace it with a “fresh” body.
Please keep your eyes open for a solid 26/27 roadster body. Some body damage is fine as long as the subframe is solid.
Jennifer
Jennifer
Jennifer
Jennifer
- First Name: Bob
- Last Name: McDaniel
Has anyone ever used the subframe from a touring of the same year to repair or replace the bad parts of a roadster? I have the touring subframe but don't have a roadster to compare it to.
- First Name: Ken
- Last Name: Buhler
- Board Member Since: 2012
A coupe sub frame would be closer but there is a difference in the rear sub cross member. I have two of them. I'll look tomorrow or Thursday and take some pictures. If that makes sense, I can drill the rivets and collapse it for easier transport. In the meantime, look back to my post titled: "Improved Open Car Surgery And Build" dated Oct 21/19 to see the bare sub frame.
Work honestly
Stay true to your word
Get the job done right
- Last Name: Pierce
Wow! That is awesome, the pictures help a great deal.Ken Buhler wrote: ↑Tue Apr 26, 2022 10:42 pmA coupe sub frame would be closer but there is a difference in the rear sub cross member. I have two of them. I'll look tomorrow or Thursday and take some pictures. If that makes sense, I can drill the rivets and collapse it for easier transport. In the meantime, look back to my post titled: "Improved Open Car Surgery And Build" dated Oct 21/19 to see the bare sub frame.
Thanks for that great reference, hoping I can pull this off!
Jennifer
- Last Name: Pierce
Bump to top
- First Name: Michael
- Last Name: Feller
- * REQUIRED* Type and Year of Model Ts owned: 1918 touring 1927 touring
There is a roadster in my sister in laws barn that my brother had I will check tomorrow to see if the subframe is in usable condition .
- First Name: Ken
- Last Name: Buhler
Hello Jennifer,
These are the photos of my sub frames. The differences are significant and they won't work.
Ken
Ken
Work honestly
- Last Name: Pierce
Thanks Ken. Those look to be in great shape, it’s a shame I can’t use them.
Jennifer
Jennifer
- Last Name: Pierce
Still looking!
- First Name: dino
- Last Name: marinelli
ebay has one for 2k plus shipping, looks good from photo, seat back is shot but overall hard find good luck
- First Name: dino
also on ebay someone is selling a 27 roadster complete, the add: 1927 MODEL T ROADSTER WITH A REBUILT ENGINE WITH 100 MILES. HAS A RUXTEL REAR AXLE, WINFIELD CARB, MATCO CROSS DRIVE, BOSCH MAG, NEW TIRES AND POWDER COATED 21" WIRE WHEELS. all for 7500 or best offer.
dont think you will be able to rebuild the body for that price. plus you can part out the accessories for most of your money back
- Last Name: Pierce
Thanks Dino, I did check both of them out - the first one has similar issues with the subframe (rotted out) you can see through the side of the lower body bucket "buns" through the where the subframe is supposed to be and see through the holes.
The other one sold before I could get in contact with the seller.
So everyone knows, this is why I am looking for a replacement subframe and/or roadster body:
I have the running gear/chassis almost complete but no body to put on it!
Thanks for your help guys!
Jennifer
Jennifer
- First Name: Kevin
- Last Name: Pharis
dinosbunny wrote: ↑Sun May 15, 2022 3:25 pmalso on ebay someone is selling a 27 roadster complete, the add: 1927 MODEL T ROADSTER WITH A REBUILT ENGINE WITH 100 MILES. HAS A RUXTEL REAR AXLE, WINFIELD CARB, MATCO CROSS DRIVE, BOSCH MAG, NEW TIRES AND POWDER COATED 21" WIRE WHEELS. all for 7500 or best offer.
Can you share a link to this auction...? Sounds an awful lot like my ol roadster...
- First Name: Kevin
- Last Name: Pharis
That’s the one! I can’t tell you how many hours of panel beating and fitting I have into that car. An original califunny car with only cosmetic rust in the trunk and below seat area (as seen in the pics). My goal for that car was to have an “original” car with no serious issues or noticeable repairs. You would have had an excellent start...
- First Name: Mack
- Last Name: Cole
ModelTGal ,to enjoy your car during the search,put a simple speedster body on it!
You can always sell the speedster body when you find the parts you needing.
I had no idea until I looked at this thread that those subframes were so expensive! i don't feel nearly as much of a cheapskate fixing mine that has some bad rust damage.
Check out this link https://mtfca.com/phpBB3/viewtopic.php?f=2&t=30258
GOOD Frame and parts - 2 cars too
- First Name: Terry
- Last Name: Woods
Jen, there is someone in Sherman, Texas that is advertising a 26-27 roadster body on Facebook Marketplace. Even if you are a Facebook member, you may not be able to view it from out of the state of Texas and Texas may be too far for you to consider.
- First Name: craig
- Last Name: leach
Hi Jennifer.
Sammy at Arizona Model A L.L.C. in Chandler Az. has a solid looking one. I do not know if it is for sale or what he would want for it if it is. email me & I will give you his info.
- First Name: michael
- Last Name: miller
- * REQUIRED* Type and Year of Model Ts owned: 1926 & 27 Roadsters 1927 Roadster pickup
Hi Jennifer, I have some 26-27 T roadster stuff which may help you rebuild your car. I'm not sure what all you are needing. Make me a list and will go from there. I'm not real close to your local; western Colorado, But maybe we can work it out. Kind Regards Mike
