MAGNETO POST ISSUE
Duckwing
First Name: Jim
Last Name: Wilson
MAGNETO POST ISSUE
Post by Duckwing » Wed Jun 15, 2022 10:13 am
My 26 T magneto quit suddenly. The mag output has been low (15 volts) for some time. I have the shim devise to take up the main bearing slack/mag gap but haven't had the energy to install it. The switch and wiring are good. I removed the post and cleaned/checked it. Still not working. I installed a repro post and have mag again. It appears that the spring loaded center contact may be intermittent. When I compress the contact, I can wiggle the post and see varying resistance readings with my ohm meter. Anybody ever experienced that malady? Is my only option to replace the post? If so, does anyone have one they will part with?
George Mills
Last Name: Mills
Re: MAGNETO POST ISSUE
Post by George Mills » Wed Jun 15, 2022 10:21 am
I had a case where I brought a car out of mothballs for a car dealer after 60 years. Exact same situation.
I kept cleaning the post and roughing up the solder blob and shaking my head...
Finally when someone was visiting with me (moxie26) he changed the mag post with a spare...life got good and stayed good!
For what it's worth.....
Post by RajoRacer » Wed Jun 15, 2022 10:41 am
The magneto contact is one place I prefer to utilize an original Ford part - some of the repros seem to have "issues" !
Duckwing
First Name: Jim
Last Name: Wilson
Post by Duckwing » Wed Jun 15, 2022 4:21 pm
I will advertise for one in the classified section. I only bought the repro part as the quickest way to trouble shoot the problem.
Last Name: House
Post by George House » Wed Jun 15, 2022 5:10 pm
Do you have an outside oiler - maybe from the side of the hogshead to the #1 main bearing ? If not, please consider an original magneto post outside oiler. I have one on all my T s. The splash system moves a huge amount of oil to the front of the engine..😁🇺🇦
Duckwing
First Name: Jim
Last Name: Wilson
Post by Duckwing » Wed Jun 15, 2022 5:42 pm
Yes, I have the outside oiler.
Moxie26
Last Name: Jablonski
Post by Moxie26 » Fri Jun 17, 2022 9:15 am
George Mills.... I was wondering where that magneto post went, lol !!! Hey have a great day.
