I have previously installed floating hubs on a 1921 T, so I know what to do at the axle.
What is the best method for separating the original 1926-7 style hub from the drum so I can install the floating hub. I know I need to somehow remove the tang in the drum and then I think I need to press out the studs but I would really like to hear from someone who has done it before and can offer suggestions on the best method.
Thanks,
Need help on 1926 hubs/drums on a rear floating hub install
