As seen in the attached photos. The frame is nice.  It was blasted and painted 20 years ago and kept inside.  There is a '26 - '27 front axle assembly and a common one.  Common differential with axles but no driveshaft.  '26 - '27 engine block that has had a crack repair, '26 - '27 transmission that looks decent, narrow nose engine pan, and some other miscellaneous bits.  It should be a good start to something for someone.
Whole pile, one money: $350
Message me through the system with your phone number and I'll call.  Thanks!
						Frame, axles, and engine -- assorted, Little Rock, AR $350
Walter Higgins
Topic author - Posts: 292
 - First Name: Walter
 - Last Name: Higgins
 - * REQUIRED* Type and Year of Model Ts owned: 1911 Open Runabout
				Steve Behrendt
 - Last Name: Behrendt
 - * REQUIRED* Type and Year of Model Ts owned: 1912 Touring, 1925 Touring
 - Board Member Since: 2022
Re: Frame, axles, and engine -- assorted, Little Rock, AR $350
Are these parts still for sale? Call me at 620 two one eight 4 two 9 two. Thanks , Steve
