Does anyone know where I can get an original 26/27 door lock key blank? Looking for a few for my 27 coupe. Ford script preferred and 2 would be awesome! An original trunk key would be icing on the cake too.
Call or text me anytime. 54zero-76one-2three03
Email me at bkirtner(at)gmail(dot)com.
PM’s generally get lost.
Brad
Wtb 26/27 Closed Car Door Key Blanks.
Adam
- First Name: Adam
- Last Name: Doleshal
Re: Wtb 26/27 Closed Car Door Key Blanks.
I might be wrong, but I doubt an original blank will fit the slot of the replacement cylinder. If it does, then you would probably have better luck finding a good used key than a blank. You should be able to have a cylinder re-coded to an existing key.
ModelT46
- First Name: Darel
- Last Name: Leipold
I have several original used keys, Ford script and numbered. If your keep/lock cylinder ils original, you should know the key number. Let me klnow th e key number and I will see if I h ave one with the same number.
