Drop front axle tie rod & drag link issue
Roger Byrne
First Name: Roger
Last Name: Byrne
* REQUIRED* Type and Year of Model Ts owned: 1911 Torpedo Open Runabout, 1914 Touring, 1912 Speedster (in progress) 1927 Touring
Post by Roger Byrne » Tue Jan 31, 2023 8:20 pm
Has any one done a speedster front suspension using a 2" drop front axle, with the early style perches, a double wishbone (above and below the axle) mounted to the engine pan (not on the outside of the frame), reverse eye spring and 26-27 spindles? If so, how did you set-up the tie rod and drag link?
Preserving Mechanical History for Future Generations since 1965
