Steering column fs. Sold
CTLeonard
Last Name: Leonard
Post by CTLeonard » Fri May 12, 2023 12:02 pm
Believe this to be the 13-15 era. Teeth on quadrant are worn. 270.00 plus shipping. ctleonard64@gmail.com
Bill Everett
First Name: Bill
Last Name: Everett
Board Member Since: 2011
Re: Steering column fs
Post by Bill Everett » Fri May 12, 2023 9:12 pm
With that firewall mounting plate, I think it may be for a '12.
Tbird
Last Name: Bird
Post by Tbird » Fri May 12, 2023 10:26 pm
Offset hole definitely a 12 feature, has square holes instead of round and the flattened control rods which were 13 features. Would be interesting to see the control rods if they have the checkered pattern. I’m guessing late 12 early 13.
Last Name: Wrenn
Post by TWrenn » Sat May 13, 2023 8:49 am
'13 also had the offset bolt hole. Sadly, and probly no one will ever know exactly when, the change was made from not only the hard rubber ends of the handles to the flattened style, as well as switching from the cast flange to pressed steel. My April 22 '13 has the steel flange FWIW.
