1925 block
1925 block
Post by Original Smith » Thu Jun 01, 2023 11:15 am
I would like to buy a good 1925 block with a 12,000,000 serial number.
CTLeonard
Last Name: Leonard
Re: 1925 block
Post by CTLeonard » Thu Jun 01, 2023 2:35 pm
I have one in Mt. Vernon in. It's a 1187xxxx which makes it a June baby. Have no idea of condition. The price is right though. Email for photos. Thank you. ctleonard64@gmail.com
CTLeonard
Last Name: Leonard
Re: 1925 block
Post by CTLeonard » Thu Jun 01, 2023 2:51 pm
Discovered I also have an 11602xxx that's in better shape appearance wise. ctleonard64@gmail.com
KimDobbins
First Name: Kim
Last Name: Dobbins
Re: 1925 block
Post by KimDobbins » Thu Jun 01, 2023 7:09 pm
Larry, check with Bill Bennet, he has one.
Re: 1925 block
Post by speedytinc » Thu Jun 01, 2023 8:07 pm
Why not get any 23-25 single valve door motor & make it into your 25, with your motor #?
Re: 1925 block
Post by Original Smith » Fri Jun 02, 2023 11:28 am
No John, that is not the way things are done!
Adam
First Name: Adam
Last Name: Doleshal
Re: 1925 block
Post by Adam » Fri Jun 02, 2023 6:27 pm
No way to tell for sure that any particular block hasn’t had that done already anyway…
Re: 1925 block
Post by Jerry VanOoteghem » Fri Jun 02, 2023 6:33 pm
Wouldn't casting dates be harder to fake/modify than serial numbers?
Re: 1925 block
Post by speedytinc » Fri Jun 02, 2023 6:50 pm
A little harder. I think the hardest thing is to find an exact matching # stamp set.
Casting date marking can be copied from the original block with a silicone mold & reset on the new block with JB weld. Paint to cover.
Re: 1925 block
Post by Scott_Conger » Fri Jun 02, 2023 7:56 pm
You know, the legal profession has a term for all or part of this, and it isn't "clever".
richc
First Name: Rich
Last Name: Chillingworth
* REQUIRED* Type and Year of Model Ts owned: 1924 C-Cab TT
Re: 1925 block
Post by richc » Fri Jun 02, 2023 8:26 pm
I have several 1926 style blocks with 1925 serial numbers available. I'm already half way to California to visit family and attend the Auburn swap meet.
Rich C.
kmatt2
First Name: Kevin
Last Name: Matthiesen
Re: 1925 block
Post by kmatt2 » Sat Jun 03, 2023 1:31 am
The 1924 and 1925 T blocks are the same and there is no casting date on them, the 1923 T block is different as it has the Ford script on the side and a slightly different shape number pad. A 1925 number beginning with 12 million will be a little harder to find because the 1926 style engines started at the 12.2 million range.
J1MGOLDEN
Last Name: Golden
Re: 1925 block
Post by J1MGOLDEN » Sun Jun 04, 2023 11:50 am
Original was very specific with what he wants.
Don't try to confuse him with facts.
Novice
First Name: Jim
Last Name: Davis
Re: 1925 block
Post by Novice » Sun Jun 04, 2023 12:21 pm
Don't make Larry blow a fuse!
