Pinion was sitting in water and is pretty pitted and the bore is scored.
The Ring gear only had surface rust and the pitting is pretty shallow- the ring gear appears to have very little wear. Ring gear would be perfect for an occasional driver if you have a good pinion. This is a Ford gear set.
$100.00 Plus $12 USPS flat rate shipping in the US. dmcgearsATyahooDOT com.
Thanks.
FS- 11/40 Ring and Pinion Gear Set-SOLD_PENDING PAYMENT
Dan McEachern
Topic author - Posts: 1512
- First Name: DAN
- Last Name: MCEACHERN
