Is there a trick to removing the upper front door hinge from the car. I managed to remove the bolts and I can get the hinge to move a little bit but they don’t want to come out of the slot!!
Any ideas/ advice would be appreciated!!
26-7 coupe door hinges!! arg!!
Topic author - Posts: 1357
- First Name: Les
- Last Name: Schubert
- First Name: Les
Re: 26-7 coupe door hinges!! arg!!
Maybe I’ve figured it out. I see there is a third bolt that is hidden!!
- First Name: Adam
- Last Name: Doleshal
Sometimes you need a slide hammer to pull them out…. But yes, get all the fasteners out first.
