Glass plate in the coils
Dennis_Brown
Last Name: Brown
Post by Dennis_Brown » Fri Feb 09, 2024 5:39 pm
Was the glass plate used in the coils used to insulate the condenser from the winding around the core or what?
Is it still used when coils are rebuilt?
Last Name: Hjortnaes
Re: Glass plate in the coils
Post by DHort » Fri Feb 09, 2024 6:47 pm
I assume it was an insulator and we put it back in when we do coils.
If you are good you never take it out and just pull out condenser and tar.
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Post by BE_ZERO_BE » Fri Feb 09, 2024 7:04 pm
The original paper capacitors have no outer wrapping or insulative covering.
Thus the dielectric strength is only what can be provided by the tar.
The glass acts as an insulation barrier between the capacitor and the high voltage windings.
Respectfully Submitted,
Be_Zero_Be
