Fan Belt Length
ModelTWoods
First Name: Terry
Last Name: Woods
Fan Belt Length
Post by ModelTWoods » Fri Oct 11, 2024 1:50 pm
Anyone running a low head on a 26-27 engine with large 26-27 crank pulley and water outlet mounted fan? What length fan belt do you use? No water pump involved.
kmatt2
First Name: Kevin
Last Name: Matthiesen
* REQUIRED* Type and Year of Model Ts owned: 26 T Coupe, 16 T Open Express, 21 TT Flatbed. 15 T Roadster, 13 & 25 T Speedster’s,51 Mercury 4 door sport sedan, 67 Mercury Cougar
Re: Fan Belt Length
Post by kmatt2 » Fri Oct 11, 2024 4:12 pm
Take a cloth tape or a heavy string and make two measurements around the pulley’s like the fan belt would run. One measurement with the fan adjuster at low point and another measurement with fan adjuster at high point. You will a fan belt that is between those two lengths.
ModelTWoods
First Name: Terry
Last Name: Woods
Re: Fan Belt Length
Post by ModelTWoods » Fri Oct 11, 2024 5:43 pm
Kevin, I knew I could do that. I was just wondering if anyone had or is doing this and what they found would work.
jsaylor
Last Name: Saylor
Re: Fan Belt Length
Post by jsaylor » Fri Oct 11, 2024 6:58 pm
I use a 32 inch on my 27 with the water outlet hub an an aftermarket aluminum lower pulley.
