WTB for 25 Touring
Ed Baudoux
Topic author - Posts: 323
- First Name: Edward
- Last Name: Baudoux
WTB for 25 Touring
Coil Box, Ignition and headlamp switches, Mag Ring, flywheel with magnets. I'm returning a car to original configuration. Grayling Michigan.
Grayling Michigan
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
Karl Von Neumann
- First Name: Karl
- Last Name: VonNeumann
- * REQUIRED* Type and Year of Model Ts owned: 1916 touring 1927 tudor 1926 hotrod 1913 speedster (project) 1926 coupe (project)
- Board Member Since: 2022
Re: WTB for 25 Touring
Shoot my and email I've got coilboxes and ignition switch I've also got the rest but would be very heavy to ship I'm in south east wi
Unless the holes for the screws holding the ring gear/flywheel have been enlarged, it would cost less to buy a set of magnets, clamp plates and mounting bolts then order the new brass screws and support spools from the suppliers. If you are going thru all this work, suggest NOT putting an old crusty failing mag plate it and get recharged magnets. Suppliers have those too.
