1915 Holley G carburetor/sold
Corey Walker
Topic author - Posts: 670
- First Name: Corey
- Last Name: Walker
New correct size float, float valve, venturi, choke spring and throttle shaft w/bushing installed. Reconditioned spray needle and spray nozzle, test run, Dec 22, 1914 patent date with brass mixture control knob and hex idle adjustment screws but steel bowl with ring around the air horn probably correct for early calendar year 1915. $250 postpaid to continental USA. Email: wlkma9@gmail.com
- Last Name: House
Re: 1915 Holley G carburetor
beautiful work Corey ! You are an artisan …
dr1960
- First Name: David
- Last Name: Ruedy
- * REQUIRED* Type and Year of Model Ts owned: 1915 Model T Runabout Pickup
I bought one of these from Corey about 5 years ago for my '15 and it runs great! I highly recommend Corey if you are looking for quality rebuilding!
David - Yukon, OK
Corey Walker
- First Name: Corey
- Last Name: Walker
Corey Walker
- First Name: Corey
- Last Name: Walker
Corey Walker
- First Name: Corey
- Last Name: Walker
Mountainrider
- First Name: Neil
- Last Name: Haywood
- * REQUIRED* Type and Year of Model Ts owned: 1915 roadster
Corey does great work. He rebuilt my G. Easy starter and runs great.
