WTB- Bosch mag drive cover
- First Name: Layden
- Last Name: Butler
Re: WTB- Bosch mag drive cover
Looks like you need more than the cover. The case has been cut away ( above the center gear) so this will mount on a later non-generator timing gear cover that the oil filler extends down farther than earlier ones. All the lube will quickly exit these 3 gears thru that opening!
- Last Name: Dickson
- * REQUIRED* Type and Year of Model Ts owned: 1912 speedster 1911 Torepdo
I have a pattern made for casting new ones but never casted any.
