Anyone know the manufacturer part numbers for the front crankshaft seal and the camshaft seal. Ex SKF or National.
Simpler for me to source from a local bearing supplier rather than the T parts supplier
Modern oil seal part numbers
- First Name: Alan
- Last Name: Stein
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring (August 1911)
Re: Modern oil seal part numbers
The marking on the crankshaft seal I used was marked: CR 9876 Made In USA. Hope this helps.
- First Name: Keith
- Last Name: Townsend
What year?
