Strobospark Repair
AndyClary
First Name: Andrew
Last Name: Clary
Strobospark Repair
Post by AndyClary » Mon Mar 10, 2025 11:19 pm
So I left my Strobospark plugged in after use, probably for a week. We’ll, it quit working. So I checked power from the transformer and it was ok. I took it apart and really had no idea what I was looking at. I noticed the panel illumination was out so I checked power to the bulb and found the bulb burned out. Replaced the bulb and everything is happy again. Just thought I’d share.
Andy
jab35
Last Name: Bartsch
Re: Strobospark Repair
Post by jab35 » Tue Mar 11, 2025 10:13 am
I think it's fairly common to have the bulb fail, especially if you use a hammer to 'adjust' the current with the coil in the unit. Fortunately replacing the bulb is a simple repair.
Last Name: Tannehill
Board Member Since: 2002
Post by JTT3 » Fri Mar 14, 2025 10:05 am
Andy thanks for the post. That’s a great repair tip. Best John
