If you need help logging in, or have question about how something works, use the Support forum located here
Support Forum
ModelTMitch
- First Name: Mitch
- Last Name: Taylor
- * REQUIRED* Type and Year of Model Ts owned: 1924 Ford Model T touring
- Location: https://www.fordmodelt.net (Manning Valley, NSW, Australia)
Post
by ModelTMitch » Sat Mar 15, 2025 2:56 am
I would like to announce that after a great deal of tinkering with code, the Model T Transmission Simulator is working again!
https://www.fordmodelt.net/transmission-simulator.htm
A small disclaimer though, the simulator uses an outdated media format called Shockwave Flash and may contain errors. It's using some clever behind-the-scenes coding trickery to make the original simulator come to life - so please persevere with it!
- Ford Model T Transmission Simulator
OilyBill
- First Name: William
- Last Name: May
Post
by OilyBill » Sun Mar 16, 2025 11:59 pm
Thank you! That is REALLY AWESOME!!
ModelTMitch
- First Name: Mitch
- Last Name: Taylor
Post
by ModelTMitch » Tue Mar 18, 2025 8:24 am
OilyBill wrote: ↑Sun Mar 16, 2025 11:59 pm
Thank you
Yes, it's great to be able to play around with this "vintage" piece of programming!!
